installing cams, what parts should i replace?
Old Apr 30, 2002 | 08:59 AM
mattL's Avatar
Default installing cams, what parts should i replace?
hi i'm dropping in some ITR cams this weekend and i just wanted to know what seals and things would be good to replace wile i have it apart, the car has 100k on it. thanks!
Old Apr 30, 2002 | 10:11 AM
IN VTEC's Avatar
Default Re: installing cams, what parts should i replace? (mattL)
Cam gear-side cam seals (91213-PR3-004) x 2 ($4.xx each)
Exhaust distributor-side cam seal (12513-P72-003) x 1 ($4.xx)
Old Apr 30, 2002 | 10:13 AM
hmonglonertim's Avatar
Default Re: installing cams, what parts should i replace? (IN VTEC)
valve cover seal and spark plug seal.
Old Apr 30, 2002 | 11:04 AM
mattL's Avatar
Default Re: installing cams, what parts should i replace? (hmonglonertim)
alright, that not too bad. anything else?
Old Apr 30, 2002 | 12:08 PM
infuryum's Avatar
Default Re:
You can actually get away without replacing the valve cover gasket or the spark plug seals. Even the Honda manual says to replace the spark plug ones only if they're worn.
While you've got the head open, it's a really good idea to replace the valve seals, if you're replacing the valve springs, as well.
Old Apr 30, 2002 | 12:15 PM
mattL's Avatar
Default Re: Re: (integral)
cool, i'm not doing that just yet. i've got the valve springs but i'm holding off on the install. thanks
Old May 1, 2002 | 04:36 AM
prelude10's Avatar
Default Re: Re: (mattL)
Don't forget to change your oil every 3000 miles, this is very important. Oh yeah you have to change the seals on the thing and on that other thing. And change your condom after every time you get some.
Lowassteg
Dec 23, 2015 07:15 AM
boostedegls
Aug 5, 2009 11:15 PM
D-rush08
Jul 24, 2006 09:34 PM
worktech
Feb 8, 2006 01:04 PM
G2Fanatic
Jul 7, 2004 03:19 PM
