Need diameter of hub for hubcentric rings
I just purchased some older style BBS RA mesh wheels. I had an idea but wasn't sure if they'd fit perfectly...they don't.
So, can anyone tell me what the diameter is on a stock 92 civic hub so I can order some rings?
I will try to find a micrometer from work, but in the meantime if someone else already knows it, that'd be great.
Modified by peacexisxfree at 1:30 AM 9/18/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisw85 »</TD></TR><TR><TD CLASS="quote">the hub size on hondas is 56.1mm</TD></TR></TABLE>
sweet. thank you.
does anyone know the outer dia?
is it 67mm?
sweet. thank you.
is it 67mm?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peacexisxfree »</TD></TR><TR><TD CLASS="quote">sweet. thank you.
is it 67mm?</TD></TR></TABLE>
umm that is the OD of the hubface that you see when you pull the wheel off. 56.1. so whatever wheel you get, if the hub bore is bigger than 56.1, you need to get a xx.xx to 56.1mm hubcentric ring set.
you're right. i suppose i misunderstood the concept of inner and outer.
