correct wheel center bore?
Re: correct wheel center bore? (kommon_sense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kommon_sense »</TD></TR><TR><TD CLASS="quote">civic hub size is 56.15mm. probably easier to just buy a set of hub rings.</TD></TR></TABLE>
so a rims center bore should match that number in order NOT to use hubcentric rings? just bolt on the rims? anyone know the center bore for rota slips 16"?
Re: correct wheel center bore? (deviant1)
bigger than 56.15. A 16" rota subzero is 67mm. You gotta remember that wheel companies make their wheels to fit as many cars as possible. So t is VERY unlikely that you will ever find a wheel that is a perfect matchfor a civic hub. Whats so wrong with getting a set of hub rings?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kommon_sense »</TD></TR><TR><TD CLASS="quote">bigger than 56.15. A 16" rota subzero is 67mm. You gotta remember that wheel companies make their wheels to fit as many cars as possible. So t is VERY unlikely that you will ever find a wheel that is a perfect matchfor a civic hub. Whats so wrong with getting a set of hub rings?</TD></TR></TABLE>
Why buy something you dont need? so as long as the center bore of the rim is bigger than 56.15mm, it will not need hubcentric rings?
