Will 17" Rims hit my Fenders?
Old Apr 30, 2002 | 07:59 AM
OldSchoolHatch's Avatar
Default Will 17" Rims hit my Fenders?
I posted this a while ago, and most people said they wouldn't. My front fenders are fiberglass, so I was worried about them getting hit on a turn if I hit a big bump. But now people are tellin me that they'll definitely rub in the back since the wheel well on the EF is smaller than the EG or EK. My hatchback isn't lowered, and my suspension is stock. If I have three 150lb people in the back seat, is it going to rub on a lot of the bumps? And what do I have to do to "roll the fenders from the inside" to make more room, is that hard to do? Thanks...
Old Apr 30, 2002 | 08:42 AM
wickedxboi's Avatar
Default Re: Will 17" Rims hit my Fenders? (OldSchoolHatch)
they shoudnt...just dont get that wide of a wheel and tire.....205/45/17 tires should be just right
Old Apr 30, 2002 | 11:09 AM
91CivicSi's Avatar
It all depends on offset and width. I have 17x7.5 SubZeros (45mm offset) and 205/40 Kumho 712s with my Skunkworks coilovers turned all the way down. The front rubs when I have the steering wheel about 1/2 turn from full lock and there is load on the front suspension.
I have about .25-.5 of a degree of camber in the rear and it barely rubs on the fender lip during hard cornering. With about .5-1 more degree of camber it would be fine.
Good luck!
Old Apr 30, 2002 | 05:03 PM
xXx Justin xXx's Avatar
if your civic is 88-91 they won't rub in the back or the front if it isn't lowered....and depending on how much you lower it they still won't rub until you get to extreme tucked witha camber kit...i know this from experience...my 87 crx rubbed with 16" rims tho...get the right offset and you shoudl be good to go.
Old May 1, 2002 | 06:14 PM
I don't know the width because the person I'm gettin em from already has them boxed up, but they're 17" Enkei Zokus with 205/40/17 Toyo tires. Can you tell the width from those tire specs? The offset is 40. Here's a pic... And can anyone tell me about rolling the fenders?
[Modified by OldSchoolHatch, 4:12 AM 5/2/2002]
Old May 2, 2002 | 11:35 AM
Anybody...?
Old May 2, 2002 | 11:46 AM
wronghand's Avatar
There is a write up on rolling fenders here: http://www.quickhonda.net/
Go to the garage section and you will see it.
Old May 2, 2002 | 12:03 PM
JohnysZC's Avatar
Default Re: Will 17" Rims hit my Fenders? (wronghand)
On a 205 17 40, your looking at about 7" to 7.5" with, they might hit.
Old May 2, 2002 | 12:29 PM
MugenRD1's Avatar
Default Re: Will 17" Rims hit my Fenders? (JohnysZC)
those look like 17x7
Old May 2, 2002 | 07:32 PM
Thanks... Wheelweights.net says that a 17x7 Enkei Zoku is 19.8 lbs. How good is that for a wheel that size? And does anyone know how much the stock 13" wheels on a 91 STD hatchback weighed? Just wondering how much these are gonna slow me down.
Old May 2, 2002 | 08:41 PM
MugenRD1's Avatar
19.8 are heavy...
Earthworm Jim
May 13, 2009 06:02 AM
sublimnal
May 15, 2005 06:46 AM
nd8ch
May 12, 2003 10:47 AM
Rydaddy
Apr 15, 2003 08:36 AM
akeldama
Apr 1, 2002 09:50 AM
