Aluminum AC mount
It replaces the engine side of the driver' side lower torque mount. If you have A/C, the aluminum mount will have to be drilled and tapped, so that the A/C compressor can be mounted on it. It is intended for cars without A/C, however.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid »</TD></TR><TR><TD CLASS="quote">It replaces the engine side of the driver' side lower torque mount. If you have A/C, the aluminum mount will have to be drilled and tapped, so that the A/C compressor can be mounted on it. It is intended for cars without A/C, however.</TD></TR></TABLE>
So that comes stock on JDM ITR's w/o AC?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 »</TD></TR><TR><TD CLASS="quote">So that comes stock on JDM ITR's w/o AC?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverDc2 »</TD></TR><TR><TD CLASS="quote">they should call it the non-a/c mount
Hahaha seriously, I wouldnt bother tapping it for A/C.
</TD></TR></TABLE>Hahaha seriously, I wouldnt bother tapping it for A/C.
If you are concerned about saving weight, dont even run those mounts at all provided you have solid urethane mounts. Some may go against my suggestion but its what I did and I had no problems with it after beating my old race car to death.
invisible
Feb 13, 2007 12:31 AM
CaptivaBlue
Mar 3, 2005 03:39 PM
