custom catch can
Old Sep 17, 2006 | 04:08 PM
onefstek's Avatar
Default custom catch can
just wanted to post some pics of the last catch can I made for my car.
enjoy......
side view
5 an-8 fittings.
2 from back of the block
2 from valve cover
1drain back to the block
bottom bracket to bolt onto car bracket
side view of the bracket and gussets
top view with filter inserted
top view with filter removed
vent holes (baffle right under the holes)
another shoot of the baffle (kinda hard to see)
bad pic of the inside baffle ( see next pic)
better pic of the baffle inside the can
another side view
close up view of the vent holes
and another one
insert filter here
Modified by onefstek at 1:34 AM 9/18/2006
Old Sep 17, 2006 | 04:36 PM
SQ is the SQUAD's Avatar
what u use to weld that up?
Old Sep 17, 2006 | 05:14 PM
c-techracing's Avatar
Default Re: custom catch can (onefstek)
nice! pretty innovative to me you get my
Old Sep 17, 2006 | 06:04 PM
onefstek's Avatar
Default Re: (SQ is the SQUAD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SQ is the SQUAD &raquo;</TD></TR><TR><TD CLASS="quote">what u use to weld that up?</TD></TR></TABLE>
its all made out of 6061-t6 aluminum, used a Lincon 185 to weld it.
Old Sep 17, 2006 | 06:16 PM
Bailhatch's Avatar
Default Re: (onefstek)
thats a cool design I think it will work really well for you. Does it go where the battery tray is?
What is that filter made out of? looks like a scotch brite or something.
Old Sep 17, 2006 | 07:14 PM
onefstek's Avatar
Default Re: (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">thats a cool design I think it will work really well for you. Does it go where the battery tray is?
What is that filter made out of? looks like a scotch brite or something.</TD></TR></TABLE>
yes it goes where the battery and fuse box used to be. and yes the filter is just a piece of scotch brite, lol
Old Sep 17, 2006 | 07:17 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
i really like that. A+ on the creativity and craftsmanship.
Old Sep 17, 2006 | 07:58 PM
Fabritory's Avatar
Good **** lets see it mounted
Old Sep 17, 2006 | 10:38 PM
.john.'s Avatar
Default Re: (Fabritory)
any reason you didnt just weld alluminum male fittings instead of bungs? i like the baffling though
Old Sep 18, 2006 | 05:35 AM
90DALS's Avatar
bungs allow easy placement of plugs incase he doesnt want to use all the fittings. i did the same design on my catch-can (using bungs so you can plug them if need be).
i like this catch can alot. you should plug the drain and run the setup for a while and let us know if it truely works or not.
Old Sep 18, 2006 | 06:51 AM
Furyof4's Avatar
Default Re: (90DALS)
Pretty inovative with the replaceable scotch brite, err filter.
Nice job.
Old Sep 18, 2006 | 07:31 AM
underpressure02's Avatar
dam looks cool. How long did that take you to make?
Old Sep 18, 2006 | 02:17 PM
Chris22215's Avatar
Default Re: custom catch can (underpressure02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Furyof4 &raquo;</TD></TR><TR><TD CLASS="quote">Pretty inovative with the replaceable scotch brite, err filter.
Nice job.</TD></TR></TABLE>
yeah I like the scotch brite idea too Good job
Old Sep 18, 2006 | 02:33 PM
short-shifter's Avatar
Default Re: custom catch can (Chris22215)
good idea on the desighn
looks like it will work well
Old Sep 19, 2006 | 07:38 AM
onefstek's Avatar
thanks guys, next im going to send it and get it powdercoated to match my sturt bar and valve cover.
Old Sep 19, 2006 | 06:20 PM
AspectIndustries's Avatar
Looks nice, one HUGE *** catch can there. -=P Planning to oil that bad eh?
Good idea with the scotch.pad
Curious why did you decide to have 2 bung on top of the can?
Old Sep 19, 2006 | 07:20 PM
onefstek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by synik &raquo;</TD></TR><TR><TD CLASS="quote">Looks nice, one HUGE *** catch can there. -=P Planning to oil that bad eh?
Curious why did you decide to have 2 bung on top of the can? </TD></TR></TABLE>
Yea its a bit on the big side , lol, but I wanted to give the oil enough time to drop to the bottom, that way there will be no oil comming out of the filter.
The two bungs on the top of the can, were simplly positioned there to make enough room for the hoses to be routed and not be so crowded.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solbrothers &raquo;</TD></TR><TR><TD CLASS="quote">gets my
pics installed please</TD></TR></TABLE>
Thanks, I don't have any pics with it installed yet. Im getting my eng bay repainted at the moment.
Old Sep 20, 2006 | 06:34 PM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
Nice work
Old Sep 21, 2006 | 11:16 AM
AMR Engineering's Avatar
That's why I asked you if you had a welder at home. I need to get a catchcan made.
Old Sep 21, 2006 | 08:25 PM
V-SPEC 1's Avatar
Default Re: custom catch can (AMR Engineering)
Nice catch can.
Old Feb 5, 2007 | 12:36 PM
onefstek's Avatar
Default Re: custom catch can (V-SPEC 1)
im still waiting for my catch can to come back from powdercoating. but it should be in soon.
Old Feb 6, 2007 | 12:21 PM
CivicVX94's Avatar
good god its taken 5 months for that to be powder coated??? wow
it's one bad *** catch can tho
i need something like that...
Old Feb 6, 2007 | 01:37 PM
QuarterMileMaster's Avatar
Default Re: custom catch can (CivicVX94)
very nice. gonna do a similar setup.
Old Feb 7, 2007 | 08:26 AM
onefstek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicVX94 &raquo;</TD></TR><TR><TD CLASS="quote">good god its taken 5 months for that to be powder coated??? wow
i need something like that...</TD></TR></TABLE>
yea im getting it done to match my strut bars and cooling plate, so its taking some time to get enough things to send to get powder coated at the same time. I can't wait till it gets back, its going to look so good.
Old Feb 7, 2007 | 07:35 PM
L-CON1's Avatar
great job man!
