b16 cooling
Old Sep 17, 2006 | 04:01 PM
90crxdxb16's Avatar
Default b16 cooling
hey i was wondering if some one could tell me which way the cooling runs on the b16.. does the coolant go into the radiator threw the bottom hose or the top.. also when i start it up do i just hook up hoses and fill up rad.? or do i need to try and get cooant into the head an block be fore i run it..
Old Sep 17, 2006 | 07:06 PM
CRX_1.8T's Avatar
Default Re: b16 cooling (90crxdxb16)
I'm not really sure what you are asking, maybe it's because I am tired. lol
Anyhoo, when you add a bunch of coolant to your car after it has been empty, it is a good idea to remove your radiator cap, and then open up that little valve by the upper radiator hose on the head and let all of the air bubbles escape the system as the car warms up and idles. other wise you might find your car overheating and stuff, and that sucks.
Old Sep 18, 2006 | 01:52 AM
90crxdxb16's Avatar
Default Re: b16 cooling (CRX_1.8T)
yea thats pretty much wat im asking i know it was empty and my first time dropping in a motor so i dont want to mess it up n have to pull it back out ya know.. once the egine gets warm the thermo. shud open and let it circulate? i should have to manualy some how get teh fluid inside .. correct?
Old Sep 18, 2006 | 01:54 AM
keepitngga1's Avatar
|| words of wisdom..first of all make sure all hoses are clamped to the radiator..than while the resovour part is open start filling the radiator thru the radiator top..i usually pump the hoses a little to get some of it thru the lines..than i proceed to add more again untill its full..make sure cap is on than jus run the car..let it cool for a lil and check to see if its full..
Old Sep 18, 2006 | 02:08 AM
90crxdxb16's Avatar
Default Re: b16 cooling (keepitngga1)
ok thanks alot.. today hopefully will be the final day of my build, when i button eveyrthing up.. and thanks to all my h-t friends u made it possible for me by solving some of my problems.. so i want to say thanks
Old Sep 18, 2006 | 02:13 AM
anytime
PatrickGSR94
Aug 19, 2008 03:48 AM
wld2rde
Feb 10, 2005 05:54 AM
blurrrcivic94
Jan 10, 2005 05:53 AM
spaceman
May 4, 2004 03:20 PM
wantmorepower
Feb 21, 2004 12:14 AM
