where do i check for cel codes in my 90 civic sedan?
Old Sep 17, 2006 | 02:43 PM
CRISIS's Avatar
Default where do i check for cel codes in my 90 civic sedan?
my dad's ef sedan keeps giving a cel and keeps dyeing. can i check the code at home and where is the harness? thanks.
Old Sep 17, 2006 | 02:46 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: where do i check for cel codes in my 90 civic sedan? (CRISIS)
Look under the carpet in the passenger side footwell, you will see the ECU, the little red light on it will blink indicating the code. Count the number of times the light blinks then that's your code number.
Old Sep 17, 2006 | 02:52 PM
CRISIS's Avatar
Default Re: where do i check for cel codes in my 90 civic sedan? (wiZCo)
do i have to have the car on or not?
Old Sep 17, 2006 | 05:31 PM
Monster.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRISIS &raquo;</TD></TR><TR><TD CLASS="quote">do i have to have the car on or not?</TD></TR></TABLE>
I think the car is off, then you turn on the ignition, right before the car cranks, and then you see the ecu flash.
I may be wrong, so if I am, then turn the car on, and see if the cel's flash etc. It's not like it will be hard to figure out which way works.
Old Sep 17, 2006 | 06:43 PM
janz3n's Avatar
Default Re: where do i check for cel codes in my 90 civic sedan? (Monster.)
ok ... since my last post was deleted.. i'll word it more nicely. you could have searched this. youv got over 300 posts and youd think you knew how to use the search button. this has probably been covered over 100 times.
Old Sep 17, 2006 | 06:48 PM
CRX_1.8T's Avatar
https://honda-tech.com/zerothread?id=1508680
For future reference, go to thie FAQ thread first. It stays right at the top of this forum. if you go there and scroll down for like .183 seconds you'll see your CEL threads.
Old Sep 19, 2006 | 01:54 PM
CRISIS's Avatar
Default Re: where do i check for cel codes in my 90 civic sedan? (CRX_1.8T)
Thanks for the help. I will go check it out.
redman223
Jul 13, 2008 01:37 PM
88backhatch
Aug 17, 2005 08:54 PM
game over
Feb 19, 2005 06:15 PM
asiansgoweeee
Jan 1, 2005 11:22 AM
S13 slide
Oct 8, 2002 01:23 PM
