Octane in the US with a jdm motor/ecu...does running 91+ improve anything?
Old Sep 17, 2006 | 12:38 AM
erikiksaz1's Avatar
Default Octane in the US with a jdm motor/ecu...does running 91+ improve anything?
I know that if a motor is not detonating, higher octanes are not required. But, 100 RON in japan is more or less 95/96 PON here (or was it MON).
So, if you're running the jdm ecu, which was worked around 100 RON, and you're running lower octane 91 gas (in california at least), will there be be a discernable loss in performance?
I'm sure it's nothing terribly significant, but has anyone tested this out?
Old Sep 17, 2006 | 05:54 AM
JOHN WAYNE's Avatar
Default Re: Octane in the US with a jdm motor/ecu...does running 91+ improve anything? (erikiksaz1)
with a high compression engine, you want to be running 93 if possible. especially on a map that was written for 100. i wouldnt be worried about performance, i'd be worried about detonation when running lower octane.
Old Sep 17, 2006 | 03:50 PM
uNF$@#!'s Avatar
Default Re: Octane in the US with a jdm motor/ecu...does running 91+ improve anything? (JOHN WAYNE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JOHN WAYNE &raquo;</TD></TR><TR><TD CLASS="quote">with a high compression engine, you want to be running 93 if possible. especially on a map that was written for 100. i wouldnt be worried about performance, i'd be worried about detonation when running lower octane.</TD></TR></TABLE>
100 RON......not octane.
Old Sep 17, 2006 | 03:59 PM
ZygSpeed's Avatar
Default Re: Octane in the US with a jdm motor/ecu...does running 91+ improve anything? (uNF$@#!)
RON = Research Octane Number
rico892002
Jul 30, 2007 05:24 AM
924doorEG
14
Jul 11, 2007 12:53 PM
plan B.
May 28, 2004 08:13 AM
goldfinger
Mar 16, 2004 01:00 PM
teamrushhatch
Jul 16, 2003 04:19 PM
