May My Sycros Be BAD???
Old Sep 16, 2006 | 10:32 PM
Extreez's Avatar
Default May My Sycros Be BAD???
Hey,
Dont even know if this problem here is just a normal gearbox of honda but it seems like my gears are really stiff and times gotta force it in, changed tranny fluid, could this be a sign of my tranny being bad ? or ?
Old Sep 16, 2006 | 10:34 PM
god.loves.ugly
Guest
Posts: n/a
Default Re: May My Sycros Be BAD??? (Extreez)
have you recently changed to a short shifter or anything? maybe it's just something with the linkage if that is the case, if not when you changed the fluid was there any metal shards or anything in there?
Old Sep 17, 2006 | 09:47 PM
Extreez's Avatar
Default Re: May My Sycros Be BAD??? (god.loves.ugly)
nope no medal chards, and i have not changed to short shifter but the previous owner could of which i fully doubt, if the medal chards came is that a sign of bad syncro? what can be the problem that i can check ?
Old Sep 17, 2006 | 09:51 PM
sablan02's Avatar
i have the same problem as you...at times its easy putting into gear and at times i gotta force it in...i had it checked..it wasnt the clutch or the fluid (which i changed)..it was a bad synchro...
Old Sep 17, 2006 | 09:56 PM
LordAphotic's Avatar
if its every gear its prolly your clutch not syncros
jdm_bones's Avatar
try doing another tranny oil change, use a green scrubber pad a filter catch...Check to see if you have any metal shavings...Then I recommend that you use Synco Mesh, tranny oil...Pick it up from your local GM dealer... Then post up!
Old Sep 17, 2006 | 10:19 PM
Extreez's Avatar
Default Re: May My Sycros Be BAD??? (jdm_bones)
its time to time some times the all gears smoothly sometimes some gears their ruff, but almost most of the time 1st gear is the worst. Im guessing clutch or syncro... anyway to check syncro to see if its bad my self ? if so how ? or can it be something wit the medal shifter that may not be connected perfectly to the transmission, maybe cuz previous owner just took the short shifter back to stock, or just loosen'd up ?
polishedturd
Nov 29, 2007 05:59 AM
bomber19
Oct 3, 2007 05:57 PM
mikseries
Honda Civic (2006 - 2015)
Feb 11, 2007 09:33 AM
bones_accord
Feb 16, 2003 08:12 PM
JM Performance
Nov 22, 2001 12:32 PM
