h22 eh2 Wont start, CEL 21
Old Sep 16, 2006 | 09:58 PM
22boost's Avatar
Default h22 eh2 Wont start, CEL 21
working on wire tuck today, relocated engine fuse box inside fire wall where passenger air bag used to be. went to start engine, cranked and then clunked....the car was running perfectly okay before i started working on it.
when i try to start the car i will crank two maybe three times and then feels as if i locks up...
WHAT I HAVE CHECKED:
fuses, none blown
thermostat housing ground, ok
12 volts at the pressure switch
ground to presssure switch seems okay
-pulled back some of the wire loom around the pressure switch and such, i didn't find any broken wires or anything yet
any ideas?
Old Sep 17, 2006 | 04:18 PM
hondaZvic's Avatar
Default Re: h22 eh2 Wont start, CEL 21 (93dxkid)
if it ran fine before, then you did something wrong. maybe u crossed some wires or something...
re-check ur wiring..
Old Sep 17, 2006 | 07:42 PM
22boost's Avatar
Default Re: h22 eh2 Wont start, CEL 21 (hondaZvic)
still unsure what the cel 21 was about. this morning i went over everything, checked for broken wires etc, found none. reconnected everything and tested it out, the cel went away.
then tried to start the car and it would crank and the quit...so i thought maybe the battery took a crap, i couldnt remeber if i had set it on the concrete at any point the night before...tried a friends battery and it did the same thing....ended up replacing the starter and it fired right up. spent all day moving wires. fun...
Old Sep 17, 2006 | 08:54 PM
hondaZvic's Avatar
wow... so after all that work, ur starter took a crap on u?... that sucks.
well, glad its fixed.
cleanwerkz
Jan 24, 2017 04:52 PM
gsmith93
May 13, 2013 02:37 PM
miguey310
Sep 13, 2011 07:55 PM
Mutiny1
Audio / Security / Video
Mar 19, 2010 04:37 AM
ludespeeder
Oct 11, 2002 08:52 PM
