ITR usdm front seat fit in EJ?
Old Sep 16, 2006 | 07:06 PM
CivicHP's Avatar
Default ITR usdm front seat fit in EJ1?
do the itr usdm not recaro version fit in a EJ1 or what is to be done to make it fit.
Modified by CivicHP at 10:32 PM 9/16/2006
Old Sep 16, 2006 | 07:15 PM
numero sete's Avatar
Default Re: ITR usdm front seat fit in EJ? (CivicHP)
I bought them for my EJ and 3 out of 4 bolts fit. Its the right rear bolt (viewed from a seated position)
I have yet to modify them. I hear the work is minimal though.
Old Sep 16, 2006 | 07:39 PM
CivicHP's Avatar
what has to be done excatly to fit the 4th bolt?does the seat sit straight is it lower?
Old Sep 16, 2006 | 07:47 PM
fucjdm
Guest
Posts: n/a
Default Re: (CivicHP)
I think you can switch your inner rails from your stock seats
Old Sep 16, 2006 | 07:50 PM
eetmaishiet's Avatar
https://honda-tech.com/zerothread?id=481758
https://honda-tech.com/zerothread?id=252542
Two links with info on installing ITR seats into an EG/EK.
Old Sep 16, 2006 | 07:54 PM
Syndacate's Avatar
It'll install, just do it from a 94-01 model. Think one hole doesn't have a bolt, and it hangs over, but not positive on that - I know you can do it without fabrication and it'll be fine (won't notice a difference) - and yes, you'll sit a bit lower.
Old Sep 17, 2006 | 09:21 AM
CivicHP's Avatar
the inners rails switch isin'tthat on the
ek(96-00).
syndacate so you saying 3/4 bolt fit and that it will be just fine like that no need to secure the 4th bolt?
Old Sep 17, 2006 | 10:28 AM
I currently have three out of four bolts in.
Seat is a little bit lower but not that noticeable. I actually like it better than my old ride height.
Old Sep 17, 2006 | 10:32 AM
CivicHP's Avatar
it hold good on 3 bolts? you used itr rails and everthing?
i am 6,3" so it good that they are a bit lower
Old Sep 17, 2006 | 12:13 PM
BlueIntegraBoy's Avatar
Default Re: ITR usdm front seat fit in EJ1? (CivicHP)
Dude, the ITR seats will directly bolt into your EJ1 without modifications. I don't know what everyone is talking about.
Old Sep 18, 2006 | 05:28 PM
The ITR seats bolt in to any 94-01 Integra and 92-95 Civic (thats an EG). The EJ chassis I believe is for the 96-98 Civic. Also commonly referred to as an EK. Please correct me if im mistaken.
Old Sep 18, 2006 | 05:32 PM
Default Re: (numero sete)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numero sete &raquo;</TD></TR><TR><TD CLASS="quote">The ITR seats bolt in to any 94-01 Integra and 92-95 Civic (thats an EG). The EJ chassis I believe is for the 96-98 Civic. Also commonly referred to as an EK. Please correct me if im mistaken.</TD></TR></TABLE>
Yes, but he's referring to an EJ1 (92-95 DX), not EJ6, EJ7, or EJ8 (96-00 DX, HX, EX).
Old Sep 18, 2006 | 06:09 PM
JDM_Frijoles's Avatar
Default Re: (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">
Yes, but he's referring to an EJ1 (92-95 DX), not EJ6, EJ7, or EJ8 (96-00 DX, HX, EX).</TD></TR></TABLE>When thefuck did this happen!? thought 92-95=EG,96-00=EK, and 01+=EP. Or some **** like that
Old Sep 18, 2006 | 06:45 PM
seanperia's Avatar
Default Re: (JDM_Frijoles)
if you read the chassis code/vin # on the "EG" coupes it would say EJ.
Old Sep 18, 2006 | 07:28 PM
duggy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Frijoles &raquo;</TD></TR><TR><TD CLASS="quote">When thefuck did this happen!? thought 92-95=EG,96-00=EK, and 01+=EP. Or some **** like that </TD></TR></TABLE>
Go look on your VIN
Old Sep 18, 2006 | 07:36 PM
Correction noted.
Thanks!
Old Sep 18, 2006 | 10:27 PM
CivicHP's Avatar
correction again EJ1 is 92-95 ex(2dr) and EJ2 is 92-95 dx(2dr) mine is EJ2.
here is a good page with chassie codes
http://www.geocities.com/Motor....html
Old Sep 19, 2006 | 10:48 AM
CivicHP's Avatar
sorry for the confusion so is it a direct bolt on on 92-95 civic 2-doors?
Old Sep 19, 2006 | 10:57 AM
LowTEC-Derbo's Avatar
yes, I'm running ITR in my EJ1
ALL EG/DC seats will fit in an EJ1 no problem. All 4 bolts will line up.
em1gangsta
Apr 25, 2008 11:20 AM
calde-da9
Aug 22, 2007 01:56 PM
98R-1144
Feb 1, 2003 05:43 PM
kappa
Sep 6, 2002 04:51 PM
ITR632
18
Apr 26, 2002 07:04 PM
