obd2 distributor power here..power there..but NO SPARK!@!!?@#$@#
Old Sep 16, 2006 | 01:39 PM
6doorsentra's Avatar
Default obd2 distributor power here..power there..but NO SPARK!@!!?@#$@#
i have power runing to my obd2 distributor..i have power in the ignitor..i have power to the coil..but i have no spark at all. This is the second obd2 distributor i've done today and same thing. I've gone through an obd1 and same results.
99d16y8-88hfcrx-
all help is appreciated, thankyou
Old Sep 16, 2006 | 01:42 PM
it cranks but no spark..
Old Sep 16, 2006 | 01:53 PM
no fuel
Old Sep 16, 2006 | 05:09 PM
Old Sep 16, 2006 | 05:10 PM
obd0 engine guide and obd2 plug guide..i just went by those and matched the wires to what they should be used for..TDC CYP etc..etc..basicly color coded
Old Sep 17, 2006 | 08:03 AM
up
Old Sep 17, 2006 | 12:23 PM
there isn't a spot to mount them on my thermostat..i checked my b18 and its on top...my d15 has it on top as well..this doesn't have anything...there are two bolts on left and one on right that hold the housing together. i put those wires on one of the bolts to the housing..still no spark
Old Sep 17, 2006 | 02:32 PM
zenon8890's Avatar
what ecu r u running?!
Old Sep 17, 2006 | 04:06 PM
p28
Old Sep 17, 2006 | 04:33 PM
slowassciv33's Avatar
Default Re: (6doorsentra)
if u dont ground the therostat wire u wont get no fuel...ground to anything good..happen to me a few days ago and it happen to be a bad connection wit the thermostat wire
Old Sep 17, 2006 | 06:34 PM
I thoght it had to be grounded on the thermostat..there isn't a spot on the d16..on my d15 there is on top and as well as my b18..where to ground??
look at the picture or do you need better?
WanderingEvil
Jul 14, 2008 12:17 AM
efdrifter
Nov 8, 2007 09:14 AM
IVI
Jul 10, 2006 01:20 PM
speedrcr24
Feb 27, 2005 07:16 PM
