shifter
i have a 94 civic dx coupe with a b16a... and when i go into gear, not matter if the car is off or on, when in gear, u can move the shift left and right about 1"-1.5", its not a big problem with shifting although sometimes its kind of hard to get into gear but not bad at all... im just wondring what could be causing this problem...?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meagainsttheworld »</TD></TR><TR><TD CLASS="quote">i have a 94 civic dx coupe with a b16a... and when i go into gear, not matter if the car is off or on, when in gear, u can move the shift left and right about 1"-1.5", its not a big problem with shifting although sometimes its kind of hard to get into gear but not bad at all... im just wondring what could be causing this problem...?</TD></TR></TABLE>
You need to tighten the bolt that goes though the shifter and the linkage.
isn't this normal? mine does the same but, it's more like an 1". BUMP, i want to know too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">
You need to tighten the bolt that goes though the shifter and the linkage.</TD></TR></TABLE>
my bolt is tight as possible and i still have play.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">my bolt is tight as possible and i still have play.</TD></TR></TABLE>
Then it's your transmission or linkage, my friends shifter just had naturally a lot of play in it, even with the bolt tight. Unbolt the linkage from the tranny and see how crisp the transmission shifts with a screwdriver.
ZachWilson23
Mar 8, 2013 09:58 PM
