Coolant spiting out of downpipe
Old Sep 16, 2006 | 10:48 AM
LaOstha's Avatar
Default Coolant spiting out of downpipe
i just installed arp head studs and mr gasket head gasket. i tried to turn the car on and it spits coolant out of downpipe. also coolant is dripping from some where in the back. I torqued all of the bolts down and put all the coolant hoses back. what can be the cause
Old Sep 16, 2006 | 10:49 AM
philosofy1's Avatar
Default Re: Coolant spiting out of downpipe (LaOstha)
is it the right gasket?
Old Sep 16, 2006 | 11:00 AM
LaOstha's Avatar
Default Re: Coolant spiting out of downpipe (philosofy1)
http://store.summitracing.com/...w=sku
Old Sep 16, 2006 | 11:04 AM
philosofy1's Avatar
hmm...your best bet is to start the car and watch from where it's coming from. it's really hard to tell just by explaining.
Old Sep 16, 2006 | 11:13 AM
LaOstha's Avatar
its hard to see when everything is in the way. when i drained the coolant it stopped dripping
Old Sep 16, 2006 | 11:15 AM
LaOstha's Avatar
and i dont want to jepordize nothing if coolant is leaking into my cylinders
Old Sep 16, 2006 | 11:16 AM
LaOstha's Avatar
im going to probably just take it apart
Old Sep 16, 2006 | 11:18 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LaOstha &raquo;</TD></TR><TR><TD CLASS="quote">im going to probably just take it apart</TD></TR></TABLE>
Old Sep 16, 2006 | 01:08 PM
LaOstha's Avatar
when i took off the turbo mani i saw water in 4 and 2. hardly any in 2 but dripping for 4. Then when i took off my intake mani it seemed the the igasket wasnt sealing good and im believe its the intake mani gasket that is letting coolant getting into the cylinders.
Old Sep 16, 2006 | 04:41 PM
92ehatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LaOstha &raquo;</TD></TR><TR><TD CLASS="quote">when i took off the turbo mani i saw water in 4 and 2. hardly any in 2 but dripping for 4. Then when i took off my intake mani it seemed the the igasket wasnt sealing good and im believe its the intake mani gasket that is letting coolant getting into the cylinders. </TD></TR></TABLE>
i dont think the intake mani gasket would cause that, but a bad headgasket would let it into the cylinders. its there to keep oil and coolant from mixing and from getting into the cylinders (and many other things). id say you either got the wrong head gasket, or its a bad one.
Sivik
Sep 1, 2016 11:59 PM
boostedNOTHARDLY
Dec 4, 2007 07:27 PM
Vtecme92
Jun 30, 2006 02:45 AM
hb_guy
Oct 29, 2005 06:12 PM
GSRaCeRbOI
Jan 12, 2003 06:31 AM
