So my DA decided to die on me while driving... wth?!
Old Sep 15, 2006 | 09:11 PM
Dee A Nine's Avatar
Default So my DA decided to die on me while driving... wth?!
Yeah, so I'm driving, and suddenly the entire car SHUTS down....
No lights are lighting from the cluster. I checked most of the wires... snug fitted. The battery isn't loose... I can't think of any other reason what's going on...
I wanna mention that my dizzy rotor was going bad before all this happened.... could this be it?
Or could it be a bad relay? I need some ideas so I can check up on it.
ANY help is greatly appreciated.
-Will
Old Sep 15, 2006 | 09:15 PM
geerexx's Avatar
Default Re: So my DA decided to die on me while driving... wth?! (Dee A Nine)
you check the voltage on the battery? also... my moms cr-v use to die while driving. turned out it was a recall on the ignition. brought it into honda and it was good to go once replaced.
Old Sep 15, 2006 | 09:19 PM
Dee A Nine's Avatar
Default Re: So my DA decided to die on me while driving... wth?! (geerexx)
Will check tomorrow afternoon after work! Thanks, any other ideas?
Old Sep 15, 2006 | 09:48 PM
DATZ WEAKSAUCE's Avatar
check all your fuses
Old Sep 15, 2006 | 10:44 PM
HBK_DAVIDDD's Avatar
Default Re: So my DA decided to die on me while driving... wth?! (DATZ WEAKSAUCE)
alternator went bad, and resulted in dead battery? maybe fuses. also check the ecu. u may want to try starting it with another one. goodluck
Old Sep 15, 2006 | 11:19 PM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
Default Re: So my DA decided to die on me while driving... wth?! (WAGOM4N)
Im assuming you know that its not the alternator? Did you car simply shut off immediately with all the accessories? Or did it take a short while?
Old Sep 16, 2006 | 12:23 AM
jdmDAsix's Avatar
Default Re: So my DA decided to die on me while driving... wth?! (STD ******)
i think its your rotor! mine did that on the freeway awhile back. i replaced cap and rotor and it was good to go.
Old Sep 16, 2006 | 06:40 AM
IHTFP's Avatar
replace your rotor...if that doesnt fix it, check your underhood fuses...
my alt was shorting out causing my main batt fuse to blow
Old Sep 16, 2006 | 06:48 AM
Hondatec38's Avatar
Default Re: So my DA decided to die on me while driving... wth?! (IHTFP)
Ignition switch posibly.
Old Sep 16, 2006 | 07:25 AM
italionstallion888's Avatar
check the plug on the alternator, mine came loose and it did the same thing. Do you loose your presets on the radio when it shuts off?
Old Sep 16, 2006 | 09:27 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
"No lights are lighting from the cluster. I checked most of the wires... snug fitted. The battery isn't loose... I can't think of any other reason what's going on..."
+1 for alternator
Old Sep 16, 2006 | 09:39 PM
Default Re: So my DA decided to die on me while driving... wth?! (ohsnapzafingcu)
Based on just the OPs first post, I would say its the alt. Hopefully he checked that; that would be the most obvious thing. I dont know how a bad rotor would make the whole car shut off though lol.
Old Sep 16, 2006 | 11:15 PM
JDMB20TDA's Avatar
if the screw fell outta the rotor its just gunna spinfreely and stop running, take off dizzy cap and check that.
Old Sep 17, 2006 | 06:52 PM
benjaminenjamin's Avatar
Default Re: So my DA decided to die on me while driving... wth?! (JDMB20TDA)
but if his rotor spins freely in the Dizzy, the battery can still get voltage to the lights....
+2 for alternator issue
Old Sep 17, 2006 | 07:19 PM
Dee A Nine's Avatar
Default Re: So my DA decided to die on me while driving... wth?! (benjaminenjamin)
Found out it was a short circuit!!!
Old Jan 3, 2008 | 10:55 AM
Canceltune's Avatar
don't mine me asking .. where was the short at?
cause one of my friend his 93 DA keep dying on him when he drive it. driving on the highway it would just cut out and will not after that.. he say about an hour or so later it would start again. does anybody know what the problem is?
dsm duster
Feb 20, 2013 06:35 PM
antiricer
13
Jan 20, 2007 02:52 PM
t0ekn3e
11
Aug 17, 2006 08:25 PM
g0rd0n
Jan 23, 2006 01:26 PM
chippy
Oct 18, 2005 06:39 PM
