which o2 sensor should i use for pr3 ecu?
hey.,
if u need on, i have the both..
email me: vntperformance@hotmail.com
thanks.
val t.
laurel,maryland.
thanks.
val t.
laurel,maryland.
if the ecu is stock then you will require two 02 sensors both are single wire
other things are knock sensor
one way to avoid the worries is to use the Mugen program which disables the knock, second 02 and vtec oil pressure switch
well wat ive done is connected both o2 wires together and hooked it up to just one o2 sensor and its work fine for me..no codes at all..runs smooth
