my rear end sounds like its falling apart
Old Sep 15, 2006 | 02:34 PM
nuggets's Avatar
Default my rear end sounds like its falling apart
my hatch sounds like it's falling apart. theirs this constant repetitive chachung chachung when i'm driving around 40+ mph. And there's like 20 million vibrations back there. I gutted the thing hopeing to find them but i havn't yet. The only thing i can think of it being is something inside the drums... i have new shocks/springs energy suspension bushing on the LCA's....
How do I go about wrenching those bad boys off of there? I've never taken a drum off in my life.
Old Sep 15, 2006 | 02:35 PM
philosofy1's Avatar
Default Re: my rear end sounds like its falling apart (nuggets)
do you have an exhaust? or maybe it's rattling because you need an exhaust? drum brakes usually don't rattle.
Old Sep 15, 2006 | 02:37 PM
cwd14's Avatar
yeha man if you go to a crappy exhaust place and they make the pipe too short it will vibrate like friggin crazy. happened to me and it was the most annoying noise I have ever heard in my life.
Old Sep 15, 2006 | 04:51 PM
nuggets's Avatar
Default Re: my rear end sounds like its falling apart (cwd14)
no my exhaust is perfectly fine. it's an RSR Exmag, sounds beautiful. It's something else that's ratteling around back there. really pisses me off.. it's so annoying
Old Sep 15, 2006 | 05:02 PM
hatch96y7's Avatar
my exhaust does the smae thing i dont think it would be because of the quality of the exhaust but it might be mounted wrong mine does it but its the rubber piece holding it is too old and got lose check urs out
Old Sep 15, 2006 | 05:03 PM
john666's Avatar
my old exhaust the tip would touch the bumper and shake the whole rear end.. interior panels and everything
Old Sep 15, 2006 | 05:26 PM
92ehatch's Avatar
Default Re: my rear end sounds like its falling apart (john666)
balance tires?
Old Sep 15, 2006 | 08:51 PM
jdeemseerx's Avatar
to take the drum off simply take your wheel off, and beat on the edge of the drum at an angle of course with the ebrake off.. then use two flatheads on opposite sides to pry it off.. if the problem is in the drum you will see it right away..i had this problem in my dodge shadow (1st car) lol one of the springs that holds the shoes together snapped and they were rattling around in the drum.. good luck
Old Sep 16, 2006 | 01:07 AM
hatch96y7's Avatar
Default Re: (jdeemseerx)
u miht want to try and put two screws nto the two hole on the drums it will make it a lot easier
Old Sep 16, 2006 | 01:39 AM
jdmOPTION2's Avatar
i got some prob. also coming from the back of my 97 ek hatch...but its coming from the inside, it only makes noise when im on a bumpy road or turning does any one here knows whats going on...? thanks
Old Sep 16, 2006 | 06:36 AM
Dwight Schrute's Avatar
Default Re: (jdmOPTION2)
check your rear trailing arm bushings. my car sounds very unconnected in the rear and i know it's because of these bushings. mine or so rotted that they are starting to crack through at some points. jack your car up in the rear, so you can see them better. you will be able to see hidden damage when the are jacked up and hanging freely.
Old Sep 16, 2006 | 08:29 AM
4thgenx42's Avatar
Check all of your rear suspension bushings, also civics are crucial to make that noise when the strut mounts have gone bad.
Old Sep 16, 2006 | 09:08 AM
Satanshatch's Avatar
I was going to say strut mounts also. Stock struts ?
Old Sep 16, 2006 | 11:14 AM
nuggets's Avatar
Default Re: (Satanshatch)
all of the bushings on the rear lower control arms were all replaced with energy suspension. new shocks, semi-new springs. the bushing on the trailing arm was not replaced and most likely is bad on both sides.
ih8speedbumps
Jan 4, 2014 03:17 AM
Dannyboy21
Sep 9, 2008 10:13 AM
douglaslovin
13
Aug 21, 2005 01:31 PM
Chief Brody
Aug 23, 2003 01:55 AM
