Changin Tranny oil?
Old Sep 15, 2006 | 10:56 AM
killakoupe's Avatar
From: San Diego to Palm Springs Runnin Things, CA, USA
Default Changin Tranny oil?
hey whats up ive searched in the [FAQ] but didnt find nething and in the search as well.
i want to do a tranny oil change and ive never done it b4. is it just like an oil change?
what oil is needed? and how much? and how do u do it? what tools are needed?
thanx for the input
Old Sep 15, 2006 | 11:07 AM
Hondaman56's Avatar
From: Filthadelphia City of Brothers and Love, PA, USA
Default Re: Changin Tranny oil? (killakoupe)
We assume you have a manual trans. There is a drain plug on the bottom side of the trans case. Break it loose. Before you remove it, look for the fill hole plug which should be up and farther back on the trans case. Find this and remove it and be sure its the correct fill plug before you drain your old oil. Drain the old oil. Clean the drain plug and reinstall. Use a Honda recomended oil and refil the trans to the specified capacity. You will need a flexible long neck funnel to do the job. Clean and replace the filler plug.
L8R
Old Sep 15, 2006 | 11:10 AM
SkoundrelUSA's Avatar
cute little bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killakoupe &raquo;</TD></TR><TR><TD CLASS="quote">hey whats up ive searched in the [FAQ] but didnt find nething and in the search as well. </TD></TR></TABLE>
LIES!
https://honda-tech.com/zerothread?id=851521
Old Sep 15, 2006 | 11:12 AM
B16b-EJ8's Avatar
Default Re: Changin Tranny oil? (SkoundrelUSA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">
LIES!
https://honda-tech.com/zerothread?id=851521</TD></TR></TABLE>
x2....i just did this the other day and found it with no problem
Old Sep 15, 2006 | 11:49 AM
killakoupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16b-EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">
x2....i just did this the other day and found it with no problem </TD></TR></TABLE>
ahh **** you got me...haha jk i search i guess i jus suck at it...but thanx for the link and thank you Hondaman56 for the input
Old Sep 15, 2006 | 01:01 PM
Malakai's Avatar
This is the 3rd post for how to change tranny fluid on the 1st page. Christ you people. Read!@
Old Sep 15, 2006 | 01:12 PM
cute little bastard
Default Re: (Malakai)
my quick write-up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">Tom I borrowed your pics
Its really really easy.
Jack the car up
Then grab your 3/8" socket wrench and loosen this bolt (the "square one" that your socket wrench will fit)
See how it pours out
Then after its all out you can do it 2 ways
1) Thread the bolt back on, lower the car and fill it back up with 2.3-2.5 qts of oil(I'll get to the filling in a sec)
or 2) Thread the bolt back on, but UNTHREAD the fill plug (picture below), lower the car so its "level" with the ground, begin filling it up until oil pours out the filler hole, and then thread it back
The reason I say this is because with the car down its more accurate as to how much oil is actually in there. But its also a pain in the *** IMO to keep jacking the car up and down and up and down.
Next unplug and unbolt the VSS.
To unbolt theres 1. I repeat 1 10mm bolt closest to the driver's side thats holding it onto the tranny.
Then just bolt back on the VSS and the drain bolt (depending on which way you decided to do it) and you're done! Don't forget to plug the VSS back on or there won't be any VTACK!!!! </TD></TR></TABLE>
Modified by SkoundrelUSA at 9:29 AM 9/16/2006
Old Sep 15, 2006 | 09:16 PM
killakoupe's Avatar
Thanx SkoundrelUSA
very helpful pics are always useful thanx again.
r_spec
Welding / Fabrication
14
Jan 15, 2007 02:38 PM
EJ8 GSR-T
Sep 4, 2005 11:59 AM
CivicRaping
Mar 26, 2005 09:55 AM
