Tranny Fluid Replacement
Old Sep 15, 2006 | 08:16 AM
paulab's Avatar
Default Tranny Fluid Replacement
Is this easy to do on the Prelude and how frequently do you all do it?
Old Sep 15, 2006 | 08:18 AM
AndyD's Avatar
Default Re: Tranny Fluid Replacement (paulab)
It's easy to drain it. Filling it back up is a different story. I made my own funnel to make filling it up easier. I used a plastic flexible tube that has an opening large enough to fit the funnel tip into.
It takes 1.9 quarts to fill it up too.
I change mine every 3 years.
Old Sep 15, 2006 | 10:20 AM
prelude1897's Avatar
Default Re: Tranny Fluid Replacement (nyluder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nyluder &raquo;</TD></TR><TR><TD CLASS="quote">I think you can remove the Reverse light switch and fill it up from there.</TD></TR></TABLE>
I heard the same thing, or it might be that silver tube that sticks out...It's one of those
Old Sep 15, 2006 | 10:26 AM
maks's Avatar
Default Re: Tranny Fluid Replacement (AndyD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">It's easy to drain it. Filling it back up is a different story. I made my own funnel to make filling it up easier. I used a plastic flexible tube that has an opening large enough to fit the funnel tip into. </TD></TR></TABLE>
I did the exact same thing, works alright. Make sure your vehicle is perfectly leveled, or else you will not re-fill it enough using this method.
Old Sep 15, 2006 | 03:14 PM
soundbomber's Avatar
Default Re: Tranny Fluid Replacement (maks)
fill from the vss, it's cake!
jit01
12
Aug 28, 2007 03:43 PM
WPG_5thgenprelude
Mar 30, 2005 03:51 PM
imadigitalgod
Oct 22, 2004 03:21 PM
danny98r
Jul 23, 2004 07:56 AM
ooooitswilson
18
Sep 15, 2003 02:09 PM
