Tranny problem. Rough Shifting
Old Sep 15, 2006 | 05:43 AM
HBK's Avatar
HBK
Default Tranny problem. Rough Shifting
So I'm late for work. It's raining. I get down the road about a mile and all of a sudden its really hard to shift. I think...**** I just blew my transmission. I turn off the road and can just get it in each gear. Normally it shifts really smooth.
Its a 91 CRX Si with a6 and si tranny with app. 240k miles on the tranny.
I just changed the transmission oil out earlier this week. I used 10w-30 motor oil if that makes a difference. Never had a problem with it before.
I managed to get it in 1st and drive home. Throughout first and second the car hesitated 99% but once I got in 3rd it drove fine.
Any ideas? I doubt my tranny oil leaked out. It could possibly be the clutch cable even though the pedal felt fine. Otherwise I have to pull the tranny and see why its rough shifting.
Please help.
Old Sep 15, 2006 | 06:14 AM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
Default Re: Tranny problem. Rough Shifting (HBK)
get a new tranny
Old Sep 15, 2006 | 11:25 AM
HBK's Avatar
HBK
bump
Old Sep 15, 2006 | 12:01 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HBK &raquo;</TD></TR><TR><TD CLASS="quote"> I used 10w-30 motor oil if that makes a difference. Never had a problem with it before.</TD></TR></TABLE>
well you got a problem with it now.
you really should have used honda MTF or any other tranny fluid. regular oil does not have the friction modifiers needed for gears.
Old Sep 15, 2006 | 12:40 PM
HBK's Avatar
HBK
Default Re: Tranny problem. Rough Shifting (Tyson)
I probly only ran it for a few days with the 10w30 in there. Do you think if I drained the oil and put in the pennzoil synchromesh I'll be alright? I hope thats all it is cause i'm on a search for trannies and beater cars now.
Old Sep 15, 2006 | 12:41 PM
Tyson's Avatar
you cant undue mechanical damage.
Old Sep 15, 2006 | 12:42 PM
HBK's Avatar
HBK
true, but I gotta give it a shot. otherwise the crx is getting parked and i'm doing a full restoration and I gotta find a beater.
Old Sep 15, 2006 | 12:43 PM
Tyson's Avatar
and you also cant do any more damage...
so nothings stopping you from trying.
are you asking for my permission to put mtf back in?
Old Sep 15, 2006 | 12:46 PM
si90rex's Avatar
check the linkage if is hard to get in gear. if the clutch was screwed up then it would grind when u go to put it in gear. i would stay bushing and linkage. but the tranny could be screwed as well.
Old Sep 15, 2006 | 12:47 PM
HBK's Avatar
HBK
no. I can't be 100% that the tranny is shot just because I drove it for a mile, but if it was a gradual thing over a few days it could be on its way out. Not a huge loss as it has 240k on it. First things first, I'm gonna change the oil out and check everything else. If its shot, I'm parking the car and buying a beater.
Old Sep 15, 2006 | 12:49 PM
HBK's Avatar
HBK
Default Re: Tranny problem. Rough Shifting (si90rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si90rex &raquo;</TD></TR><TR><TD CLASS="quote">check the linkage if is hard to get in gear. if the clutch was screwed up then it would grind when u go to put it in gear. i would stay bushing and linkage. but the tranny could be screwed as well.</TD></TR></TABLE>
i'm almost positive that its teh oil I put in there. It was kinda sketchy going in and I'm not 100% on how much is in there. I've been keeping my eyes out for a beater anyway so I can park the crx for the winter but this caught me by surprise.
my linkage is good and I have poly bushings.
Old Sep 16, 2006 | 08:13 PM
HondaHeddie's Avatar
how come the factory manual, and every dealer I have asked, says regular oil is what is used and the honda fluid is just the same only $$$$
I am running mobil1 10w-40 and have no complaints
Old Sep 16, 2006 | 08:30 PM
Tippyman's Avatar
Penzoil Synchromesh is all I have ever run through my three trannies and all I will ever run.
Old Sep 17, 2006 | 11:26 AM
HBK's Avatar
HBK
Default Re: (Tippyman)
After I drained the regular oil out and figured I had no 1st or 2nd gear, I started playing with the shifter and just slammed it into 1st. After that it felt fine so I filled it up with 2 pennzoil synchromesh quarts and It's been driving fine since. I'm just waiting for it to crap out on me even though it doenst make sense for it to in the first place.
poormans_typer69
Nov 6, 2007 06:57 PM
delsol revolution
May 2, 2007 08:08 PM
HBK
Sep 15, 2006 02:47 PM
tgreaves
Feb 2, 2004 07:09 AM
ALTERED4
Jan 30, 2003 11:46 PM
