Going LS-V. Which ECU to use???
Old Sep 14, 2006 | 07:07 PM
1fastvtec's Avatar
Default Going LS-V. Which ECU to use???
Obviously needs to be a B16A or B18C ECU. Running Chrome to tune with. Also, does anyone know of a plug-n-play conversion harness for a 93' Integra LS?
Thanks!
Old Sep 14, 2006 | 07:31 PM
LordAphotic's Avatar
if your gona chip it with chrome to tune it... you dont need a b16 or b18c ecu. use your stock one.
Old Sep 14, 2006 | 08:23 PM
JasonST's Avatar
Default Re: (LordAphotic)
What kind of conversion harness? U can get obd conversion harnesses from a few different places, I got mine from jdmsh!t.com... They're a good place though the sauders are pretty dinky so don't fudge with em too much or bend them alot. O and of course the ! is an i if u go to their websight, I also heard that Hasport and a few other places make conversion harnesses, even ppl here on H-T.
Old Sep 14, 2006 | 08:24 PM
qfast817's Avatar
i used a obd1 p-72
Old Sep 14, 2006 | 08:28 PM
K2sInteg98's Avatar
Default Re: (qfast817)
i used a p28, i tuned with chrome.
Old Sep 14, 2006 | 08:41 PM
b20powereDA's Avatar
Default Re: (K2sInteg98)
why do u need a conversion harness? ur car is obd-1.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LordAphotic &raquo;</TD></TR><TR><TD CLASS="quote">if your gona chip it with chrome to tune it... you dont need a b16 or b18c ecu. use your stock one.</TD></TR></TABLE>
u can use a stcok ls ecu on a ls/vtec as long as its chipped for crome? i thought that wasnt possible because its non vtec.
Old Sep 14, 2006 | 08:54 PM
adseguy's Avatar
Default Re: (b20powereDA)
1st time I come back to the Integra forumform the FI and I see all this ****
You need a VTEC ECU...either solder in a VTEC controller onto the LS ECU or just buy a VTEC ECU.
Next it's CROME as in Chui's ROM Editor not "BLING"
You won't need a harness if everything is the same OBD as you started with.
/thread
Old Sep 14, 2006 | 09:27 PM
Default Re: (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">1st time I come back to the Integra forumform the FI and I see all this ****
/thread</TD></TR></TABLE>
thats what i thought. when LordAphotic said that i was like WTF?!? did someone come up with a way for this **** to be done so easily. but thanks for clarifying that. i feel like a f*cking noob for asking a stupid question like that. oh well, u live and u learn
Old Sep 15, 2006 | 02:02 AM
hothotpete's Avatar
i using a chipped p28
Old Sep 15, 2006 | 06:22 AM
mr.beeks's Avatar
Default Re: (hothotpete)
PS upgrade your injectors and use a hondata ecu and tune it.
cause most cases CYL #1 end up blowing up cause of poor fuel mixture.
Old Sep 15, 2006 | 09:58 AM
adseguy's Avatar
Default Re: (mr.beeks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.beeks &raquo;</TD></TR><TR><TD CLASS="quote">PS upgrade your injectors and use a hondata ecu and tune it.
cause most cases CYL #1 end up blowing up cause of poor fuel mixture.</TD></TR></TABLE>
WHAT?!?!? Cylinder #1 is not more likely then any other cylinder except #3 which is the hottest running, but still......WTF is going on here
Old Sep 15, 2006 | 11:29 AM
1fastvtec's Avatar
Dude, mellow out. I asked a simple question. Good hell. I wasn't asking about a conversion harness, I was asking about a plug-n-play harness. So I don't have to cut into my existing harness for the Vtec ECU. I know I need a Vtec ECU, does it matter which one?
Old Sep 15, 2006 | 11:33 AM
VTECth1s's Avatar
Default Re: Going LS-V. Which ECU to use??? (1fastvtec)
any vtec ecu preferably obd1 chipped p72 or p28, tune it and call it a day
Old Sep 15, 2006 | 12:23 PM
1fastvtec's Avatar
Thanks egg6vtak. Thats all I wanted to know. Simple.
Old Sep 15, 2006 | 11:27 PM
VTECth1s's Avatar
Default Re: (1fastvtec)
anytime, but i would go with a chipped p28 over the p72 any day.
Old Sep 17, 2006 | 04:45 PM
1fastvtec's Avatar
What type of chip would I need to use to run the crome tuning? Can someone like Kenji do it? Also, the head is off a 97 GSR, does that make any difference?
Old Sep 17, 2006 | 08:09 PM
VTECth1s's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1fastvtec &raquo;</TD></TR><TR><TD CLASS="quote">What type of chip would I need to use to run the crome tuning? Can someone like Kenji do it? Also, the head is off a 97 GSR, does that make any difference?</TD></TR></TABLE>
you could use any chipped ecu, go with a reputable company of course...if you have a gsr head and you plan to keep it stock, then run a stock obd1 p72 most definitely, but if you plan to changing the IM to skunk2, blox..etc then definitely get a chipped obd1 p28.
Old Sep 17, 2006 | 08:55 PM
jdm_bones's Avatar
I would have to agree on the P28 obd1 chipped FTW...
But there is also the P72 GSR,
and the PR3 B16A Civic,
and the harder to find P73 ITR,
and the even harder to find P30 from the Del Sol SiR...
Old Sep 17, 2006 | 08:59 PM
jdm_bones's Avatar
Do you even know what you are talking about, you can't use a non VTEC ECU, on a VTEC SET-UP...THAT **** WOULD RUN LIKE ****....come on now, stop misleading people!
Old Sep 17, 2006 | 09:12 PM
RJonathan's Avatar
Default Re: (jdm_bones)
what he is talking about is using the stock PR4 ECU from the 93 integra and having someone like J-K tuning or Kenji convert it to Vtec and chip it. Reason being is because 93 came OBD1 PR4 ECU which is easier to covert to Vtec than the P75 94 integra ECU.
I personally have converted a P75 to Vtec and it would stay in vtec for a bit then throw a codes. but with the PR4 its easier to convert it to vtec, it tends not to throw any codes. Even tho when looking at the circuit board everything is pretty much the same except for a few things here and there.
There are alot of ECU option out there
P72-GSR
P30-Delslow
PR3 B16
P73 ITR.
P28 Chipped
P06 Chipped and Convert for Vtec.
If I were you I would use the PR4 in your 93 teg and have it converted to vtec and chip with custom basemap.
prionailurus
Mar 25, 2008 12:28 AM
jakedoza
Oct 4, 2006 04:32 PM
CRXLST
13
Sep 25, 2004 07:32 PM
Danethomp
Apr 22, 2004 06:52 PM
