ABS light/power problems???
My 1995 Integra has the good old buzzing ABS pump, and I have gotten used to it by now. But lately, about every other day or so (usually at night) the ABS light will come on and the wierd thing is, when it does, it seems like a power surge. My headlights will dim, and even the radio will power off and on real quick. Does anyone have any idea as what the problem could be? Thanks for all your help in advance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atg1290 »</TD></TR><TR><TD CLASS="quote">Might want to check you grounds and is the battery in charge?</TD></TR></TABLE>
Are you referring to the battery ground? Can I test the battery with a multimeter?
Scratch that battery idea.. I would check all the grounds and make sure its touching bare metal(if it was recently painte) Im not sure but it maybe something wrong with the alternator/?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atg1290 »</TD></TR><TR><TD CLASS="quote">Oh yeah..try anf pull the code and then that will help us alot..</TD></TR></TABLE>
No paint work at all lately (several years, and none under hood ever) Is there any easy way for me to pull the codes?
shandar
Jul 11, 2017 08:59 AM
tlarimer
Jul 15, 2009 05:24 PM
