PROBLEM WITH A/C IN A 92 CIVIC
Old Sep 14, 2006 | 07:02 PM
92EG8's Avatar
Default PROBLEM WITH A/C IN A 92 CIVIC
FIRST EXCUSE THE CAPS (KEYBOARD CAPS IS BROKEN). I HAVE A 1992 HONDA CIVIC LX EG8. A COUPLE DAYS AGO I HAD CHANGED A COUPLE OF FUSES BECAUSE SOME WERE BURNED OUT (USE FUSE TESTER). AFTER DOIN THIS IS RESULTED THAT MY CAR A/C IS ACTING WEIRD.[WHEN I BOUGHT MY CAR THEY TOLD ME I NEEDED TO REPLACE THE COMPRESSOR BECAUSE IT WONT BLOW COLD AIR]. WEL STRAIGHT TO THE POINT. MY A/C NOW SHORTS AND CUTS MY CAR OFF ONCE I GO PAST THE FIRST SETTING 1. [2 3 4 WILL TURN OFF MY CAR AND MAKE WEIRD SOUND SOMEWHAT OF THE STARTER GRINDING WHEN YOU TRY TO TURN ON YOUR CAR WHILE ITS RUNNING]. I TRIED TO SEE IF IT WAS MY IDLE BUT IT ISNT. AND THE FUNNY THING IS WHEN MY CAR IS OFF I CAN GO ALL THE WAY TO 4 WITH NO PROBLEMS. MY QUESTION IS ==== WHATS CAUSING MY CAR TO SHUT OFF ONCE I ENGAGE THE A/C TO A HIGHER SETTING.
{ALSO HOW DO I KNOW IF I NEED A NEW COMPRESSOR. FROM WHAAT I VE HEARD I JUST NEED A RECHARGER BECAUSE IF THE A/C DIDNT WORK IT WOULDNT BLOW BUT MY A/C BLOWS WHEN I IGNITE THE A/C JUS HOT *** AIR...SO WHAT CAN I DO BOUT CHECKING WHY MY AC WONT SHOOT COLD AIR OUT. ]{
ALL HELP IS APPRECIATED THANK YOU.
AJ
Old Sep 15, 2006 | 12:45 PM
92EG8's Avatar
Default Re: PROBLEM WITH A/C IN A 92 CIVIC (92EG8)
bump
Old Sep 15, 2006 | 01:02 PM
-Gary-'s Avatar
They might not be helping you because of the CAPS.
Old Sep 15, 2006 | 01:08 PM
slow_evo's Avatar
Default Re: (-Gary-)
Just trace the wires from your A/C switch and see where they go.
that's where I would start.
But it sounds like a very wierd prob.
Old Sep 16, 2006 | 08:16 AM
92EG8's Avatar
Default Re: (slow_evo)
hmm well anyone else have any suggestions onto why this is happeniing
Old Sep 16, 2006 | 08:26 AM
nsxmatt's Avatar
Could be the compressor shorting out or drawing too many amps. Usually it would just blow a fuse but seeing as you have had some wiring issues I wouldn't be surprised if someone hadn't hardwired it in the past.
Old Sep 16, 2006 | 09:38 AM
Frozen E's Avatar
H-T White Ops
JESUS CHRIST THAT ALL CAPS THING IS ANNOYING. THAT'S ALL I HAVE TO SAY ABOUT THAT. DIDN'T EVEN READ IT.
Rewrite the damn thing like a normal person and I bet you'll get more responses.
Also, I call Bullshit on your caps key being broken. You registered yesterday and this is what you typed in when you registered
Access Level Normal User
Permission Level Restricted Trial User
Full Name Adrian Miguez
Email Address dopeboyj@gmail.com
Location Homestead FL Miami Dade County
Age 16
AIM Name TaLenT183
Home Page View
They're all typed normal. Damn kids these days.
Old Sep 16, 2006 | 10:08 AM
nsxmatt's Avatar
Default Re: (IslandSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi &raquo;</TD></TR><TR><TD CLASS="quote">JESUS CHRIST THAT ALL CAPS THING IS ANNOYING. THAT'S ALL I HAVE TO SAY ABOUT THAT. DIDN'T EVEN READ IT.
Age 16
AIM Name TaLenT183
Home Page View
They're all typed normal. Damn kids these days.</TD></TR></TABLE>
Pretty pathetic you took the time to go to his profile and cut and paste into a new post just to try and be a hardass. Now who is the one acting like a kid now? Crybaby, you don't like caps then move on.
Old Sep 16, 2006 | 10:12 AM
philosofy1's Avatar
Age 16
AIM Name TaLenT183
Home Page View
the amount of time you put into this, you could of use that time and posted someting technical that will help his problem.
Old Sep 16, 2006 | 10:56 AM
92EG8's Avatar
Well what do we have here secret agent man...If I would've asked you to solve my CAPS then you'd have a right to post ...Im asking for help dumbass.This is a Technical Forum correct where people can help each other instead of try to criticize shyt. Anyways Im gonna do a fuse check all over maybe there is one fuse not doin good.As for the Islander Retard....Yeah I'm a kid EVERYONE was one too...shut up and move on.
Old Sep 16, 2006 | 11:18 AM
Frozen E's Avatar
H-T White Ops
1 little, 2 little, 3 little bitches......you know how the rest goes.
Get butthurt much? Go outside and go play in the sun or something.
Old Sep 16, 2006 | 11:22 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi &raquo;</TD></TR><TR><TD CLASS="quote">1 little, 2 little, 3 little bitches......you know how the rest goes.
Get butthurt much? Go outside and go play in the sun or something.</TD></TR></TABLE>
sorry if i hurt your feelings when i called you out. the truth hurts though. now i know why your % is low, keep it up homie, it's only going to go lower!
Modified by philosofy1 at 3:43 PM 9/16/2006
Old Sep 16, 2006 | 01:47 PM
Frozen E's Avatar
H-T White Ops
Default Re: (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">sorry if i hurt your feelings when i called you out. the truth hurts though. now i know why your % is low, keep it up homie, it's only going to go lower!
Modified by philosofy1 at 3:43 PM 9/16/2006</TD></TR></TABLE>
And you are.........?
92civhatch1125
11
Aug 6, 2013 09:26 AM
new4ucivic
Mar 21, 2012 12:36 PM
ssj4trunks09
Nov 12, 2008 12:53 PM
