black smoke
yea definitly tune it........it makes a differnce.........with the black smoke, you hittin vtec its burning oil, theres gonna be smoke coming out..........you might be running rich, your bottem end might have gone, your pistin rings are fried........theres a couple of things
u dont need to get it tuned right away i mean tuning it may help you out, but theres also other things like have u changed your oil recently, if not change it and see how that does, your cat may be all hallowed out, is it stock exhaust or what u got.........i mean if u tune it, get it tuned right with launch control and **** like that
now i only got apexi exshust and intake for my stock GSR.........and also Dyno told me to get tthe obd1 ecu to tune it........should i set my vtec cliicks in in 4000rpm?? and also do u think my car will be more smooth and faster after i fix the black smoke power and tune it up??? thanks for answering me!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ac_attak »</TD></TR><TR><TD CLASS="quote">Any check engine light? Could be a bad o2 sensor.</TD></TR></TABLE>
theres no engine light on......do u think is the piston problem??is it too old to make this happen??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ac_attak »</TD></TR><TR><TD CLASS="quote">Naw if you are sure the smoke is black then it wouldnt be piston blow-by. That would cause blue smoke.
Are you burning any oil?</TD></TR></TABLE>
yea i m sure that is black smoke and my engine oil are burnning so fast
specially when i clicks in vtec or high rpm
joehonda1129
Nov 29, 2007 02:35 PM
FLCivic
Feb 19, 2003 07:10 PM
