Swap an Obd2a B16A2 into an obd1 EG ?
Old Sep 14, 2006 | 01:28 AM
Nagata-San74's Avatar
Default Swap an Obd2a B16A2 into an obd1 EG ?
Yo
I don't post often here, but I couldn't find my answer
I've just bought a setup...
It's a B18c4 (gsr) with a B16a2 (ek4) head. So the engine is now OBD2a
But my EG is OBD1, running a P28 with S300 Hondata.
Question is, how to fit it right in the car ?
i got the harness jumper, but what about the cluster/dash ?
DOes anyone have the cluster's harness full shema ??
Someone told me it would be easier to fit an eg6/9/2 obd1 ignition + vtec solenoid to make the engine obd1.
Any one, HELP ME !
Old Sep 14, 2006 | 02:31 AM
fmrprojects's Avatar
Default Re: Swap an Obd2a B16A2 into an obd1 EG ? (Nagata-San74)
just run everything obd-2 in the engine bay and use a obd-2 LS or GSR harness and then plug in a obd-1 ecu.
Old Sep 14, 2006 | 04:20 AM
Default Re: Swap an Obd2a B16A2 into an obd1 EG ? (fmrprojects)
yeah but what about the dash ? I need to see rpm, speed and lights on the cluster !!
Old Sep 14, 2006 | 04:48 AM
myEK=slow's Avatar
i had the same idea as you.... it will work trust me. your dash is not affected..
Old Sep 14, 2006 | 07:26 AM
Default Re: (myEK=slow)
So could you please write me what you exactly did, like witch mods you made !
Thanks yet !
Old Sep 14, 2006 | 07:03 PM
myEK=slow's Avatar
basically you need an obd2a or b wiring harness, i used A. should be all plug and play for your motor if its all obd2a. or b. but anyways. with the obd2 wiring harnesses, tehy went straight through the dash, no connecting harnesses like in Eg's. so than you get your obd2 to 1 cjumper harness, plug that into your ecu and you should be fine.
eghatch03
May 25, 2016 03:44 AM
egY5
Nov 14, 2012 03:39 AM
jaap_15
40
Mar 10, 2011 07:44 PM
sh4mr0ck
Jun 20, 2009 11:51 AM
Paulnsx
Jan 12, 2005 01:09 PM
