gsr vavle cover
im going to change my stock gsr valve cover for a type r cover thats on my b16,do i half to change the valve cover gasket or can i strait swap with out buying new gaskets
It's a very good idea to change the vc gasket. Especially with all those miles on the motor. I could understand if the motor was new, but yeah, it's recommended.
yes like he said^^^ it is a very good idea to change it. they are not that expensive and it will make things that much easier if you install the old one and it leaks and you have to do it over again, even though its not a big pain to swap it out. I always use new gaskets on everything i take apart.
should be fine w/o replacing it.... b16a and b18c use the same valve cover gaskets. Of course it is recommended that you do replace the gaskets though.....
Nicks95GSR
Jun 2, 2008 03:24 AM
type Gendy
10
Sep 6, 2003 10:44 AM
