How do u PROPERLY install the Power Enterprise belts when having big lobed cams (Todas / Juns)
Old Apr 29, 2002 | 06:21 PM
SpoonFed's Avatar
Default How do u PROPERLY install the Power Enterprise belts when having big lobed cams (Todas / Juns)
Just wondering how u properly install the PE belts because I heard the factory method is incorrect if running the big cammed and stiffened spring motors... Make sense.... but please let me know how to thanks
Old Apr 29, 2002 | 07:02 PM
Pinhead's Avatar
New User
Default Re: How do u PROPERLY install the Power Enterprise belts when having big lobed cams (spoonfed)
I'm wondering this as well Thanks in Advance
Old Apr 29, 2002 | 07:11 PM
sgT's Avatar
sgT
Default Re: How do u PROPERLY install the Power Enterprise belts when having big lobed cams (Pinhead)
Manually tension the belt and remove ALL of the slack.
You want to do this with the engine hot as well so that you dont get any
overly excessive tension. Keep in mind this will cause more wear on the cams,
#1 upper main bearing, tensioner and water pump. But hey, you want power right?
This is especially important if you turn high rpm. This is why i dont bend valves
in case some of you were wondering. When you mishift the timing changes
and then you bend valves. This way there is no way the timing can change
because there is -0- slack.
Old Apr 29, 2002 | 07:19 PM
Rob :190:'s Avatar
Default Re: How do u PROPERLY install the Power Enterprise belts when having big lobed cams (sgT)
more wear? would that mean the no tension setup would be bad for a street car?
Old Apr 29, 2002 | 07:24 PM
sgT's Avatar
sgT
Default Re: How do u PROPERLY install the Power Enterprise belts when having big lobed cams (Brian Spilner 1
i have a street car, car gets driven about as much as a taxi cab.
I do regular maintenance, and extra maintenance on a regular basis.
Once again, this is one of those things you have to do. If you are squeamish,
then stay with stock parts.
Old Apr 29, 2002 | 07:25 PM
Rob :190:'s Avatar
ok, thanks for the info.
Old Apr 29, 2002 | 07:29 PM
t's Avatar
t
sgt-I would assume this would contribute to causing the timing belt to snap due to it being stretched real tight? I assume when you say maintenance you change your timing belt frequently?
Old Apr 29, 2002 | 08:06 PM
sgT's Avatar
sgT
Timing belts dont SNAP. The teeth fall out. proper tension or not, with a stock
timing belt it WILL happen. Its just a matter of time.
I use a power belt. so far it seems to be holding up very well.
when i say maintenance, i mean the following:
check main and rod bearings
check oil pump
check cams
check tensioner
check water pump
check timing belt
theres more, but i dont remember right now.
lsteg94
Oct 14, 2007 07:59 PM
Beave0101
13
Nov 6, 2003 10:21 PM
ingrate
Dec 9, 2002 09:21 PM
MikeSarr_GSR
Dec 3, 2002 11:19 AM
Speedz
Apr 30, 2002 01:07 PM
