Need help ASAP..question about cooling hoses on H22 prelude
Old Sep 13, 2006 | 04:45 PM
TopEndUSA's Avatar
Default Need help ASAP..question about cooling hoses on H22 prelude
Hey,
On the prelude You guys know the hose that runs from the side of the head to the little black box mounted on the fire wall with the cable (like a throttle cable)---then there's another hose that curves and goes to the firewall?
If I remove the curved one, Is it okay to bypass the little black box (what is it?) by running the hose straight from the side of the head to the firewall?
Old Sep 13, 2006 | 05:01 PM
kb58's Avatar
Banned
Default Re: Need help ASAP..question about cooling hoses on H22 prelude (MardreRacing)
I believe that's your heater lines, and yes you can bypass the "box". You will of course lose heater operation.
Old Sep 13, 2006 | 05:16 PM
TopEndUSA's Avatar
Default Re: Need help ASAP..question about cooling hoses on H22 prelude (kb58)
Will it adversely affect the engine with more heat?
Old Sep 13, 2006 | 05:24 PM
Silver Surfer's Avatar
no, but this seems kind of stupid and pointless
both of those hoses run to and from the heater core
the cable is linked to a lever which connected to another cable that is connected to the slider bar on your climate control face........this cable(the part in the engine bay) connects to a solenoid(it sits inline on one of the hoses) and opens and closes it when you slide from hot to cold
why would you want to bypass these lines?.......it's cold in VA
Old Sep 13, 2006 | 05:43 PM
TopEndUSA's Avatar
Default Re: Need help ASAP..question about cooling hoses on H22 prelude (Silver Surfer)
The hose that goes to the firewall has a hole in it, I was just wondering should I replace it or bypass it. I didn't know what it was for. However, I'm moving to FL next month.
Old Sep 13, 2006 | 05:50 PM
the hose is like $10-$15
just replace it.....it will be baked on so you will probably have to cut it off
it was a pain in the *** when i replaced mine for the jdm climate control
i had to slit the hose with a knife and pry them loose with a flathead.....then used some petrolium jelly to slide the new ones on
you'll need some jack stands and a creeper for it not to be a total pain
Old Sep 13, 2006 | 05:56 PM
TopEndUSA's Avatar
Default Re: (Silver Surfer)
Yep, I took it off tonight. I took awhile to get it off and yep I had to cut it and pry it off. I guess I'll just replace it in the morning. Thanks guys
Please close thread
Wagovan_AK
May 15, 2013 10:27 PM
91prelude4me
Apr 6, 2010 03:46 PM
jyacoba2009
Dec 6, 2009 07:35 AM
crex23
Nov 3, 2009 06:08 AM
UpstateCivic
Jun 6, 2003 05:40 PM
