How to replace a valve Cover bolt
Can any one tell me where i can get the bolt NutBoot.and and how to replace it..Its a Non vtec the One all the way to the left hand side where the cruse controle wire runes in to
WTF??
you remove the bolt by turning it counterclockwise.
bolts and bolt rubber/seat are sold in honda
rune in? wtf? did you snapped the bolt?
rusted? stripped? jebus?
Well i broke the stud trying to retighten it and i should have refrased that question to how do i reaplace the Broken stud on my valve cover and where to do i get another bolt and the ruber busshing
go to the junk yard get a good one, and if you have enough rome vice grips should work. if that just takes down the thread, try irwns bolt removers, they are revised threaded to cut into d bolts, and nuts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaccord »</TD></TR><TR><TD CLASS="quote">go to the junk yard get a good one, and if you have enough rome vice grips should work. if that just takes down the thread, try irwns bolt removers, they are revised threaded to cut into d bolts, and nuts.</TD></TR></TABLE>
they sell a reverse grip for broken stud, mostly will not work if you torque them down really good. most of the time you'll be faster drilling the bastard out.
bolt and bushing will be availble in honda, get it new, nothing is worth than snapping another bolt after you remove the old one.
Those studs act as a cam cap bolt. They have a bolt head at the bottom of the stud part where you broke it. Just unscrew it and put a new one in. They break often, just be careful next time since you put a ton of pressure on it the first time.
SO all i would have to do is grab a pair of vice grips and un screw the valve cover? man how come i didnt think of that
Remove your valve cover and use a wrench there is a nut on the stud to remvoe it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamlegacy »</TD></TR><TR><TD CLASS="quote">Those studs act as a cam cap bolt. They have a bolt head at the bottom of the stud part where you broke it. Just unscrew it and put a new one in. They break often, just be careful next time since you put a ton of pressure on it the first time.</TD></TR></TABLE>
Just as he said.^^
Just as he said.^^
Jay J
Jul 22, 2006 09:33 PM
murmur9
Mar 10, 2006 05:06 PM
LoudAccord
Jan 9, 2003 10:43 AM
