starter grind with aftermarket flywheel......
Old Apr 29, 2002 | 05:20 PM
non-VTEC's Avatar
Default starter grind with aftermarket flywheel......
i recall some people haveing the same problem i'm having with my starter and aluminium flywheel. most of the time it will start up fine........but somtimes when i go to crank it over i'll get a grinding sound......
does anyone remember if there is a easy fix for this? maybe shift the starter around a little? modify the starter teeth?
thanks
Old Apr 29, 2002 | 05:23 PM
t's Avatar
t
Default Re: starter grind with aftermarket flywheel...... (non-VTEC)
You will need to file down the starter gear teeth. It is due to the starter teeth tolerances.
Old Apr 29, 2002 | 05:29 PM
non-VTEC's Avatar
Default Re: starter grind with aftermarket flywheel...... (t)
how much do i have to take off?
anyone have any before and after pics of the starter after it's been modified?
Old Apr 29, 2002 | 05:31 PM
B2FiNiTY's Avatar
What flywheel did you get?
Old Apr 29, 2002 | 05:38 PM
non-VTEC's Avatar
Default Re: starter grind with aftermarket flywheel...... ( B2FiNiTY)
it's made by a small company. not very popular right now........but they tested it on many differnt engines (B16, B18) and only some will grind........maybe it's the starter type?
Old Apr 29, 2002 | 05:42 PM
t's Avatar
t
In that case, it might be the flywheel ring gear. Filing the stater teeth may or may not fix your problem if it has to do with the ring gear not made to the correct specs.
Old Apr 29, 2002 | 10:43 PM
lotus's Avatar
New User
Thought I read somewhere that you could sub a civic starter to cure the grinding on some of those flywheels... Might be something under the search..
Fowled
Apr 25, 2015 11:28 PM
MikekiM
Jan 18, 2005 09:47 AM
92lsr
Jan 17, 2004 09:27 AM
SpoolnG2
Dec 27, 2002 10:27 AM
