supercharge
Old Apr 29, 2002 | 05:20 PM
maximedx's Avatar
Default supercharge
can i supercharge my d16a6 block with 11:1 piston or can i put turbo on it.
Old Apr 29, 2002 | 05:26 PM
EP3_05's Avatar
Default Re: supercharge (maximedx)
You can do either but tuning is going to be critical with that high of a compression ratio. I would recommend lowering it if you want run a good amount of boost with a supercharger or turbo.
Old Apr 29, 2002 | 05:30 PM
91civ's Avatar
if you want to lower your compression i am pretty sure that GSR pisons are the best choice...i'm not 100% so if anybody else knows please chime in
Old Apr 29, 2002 | 05:43 PM
EP3_05's Avatar
Default Re: supercharge (91civ)
He may just want to sell his high comp pistons and get some low comp ones. The GSR pistons will not fit in a d16a6 block since the GSR has a much larger bore size than the d16a6. He could also get a thicker head gasket to lower the compression a bit otherwise he would really need to look into new pistons.
Old Apr 29, 2002 | 05:46 PM
91civ's Avatar
Default Re: supercharge (91civic)
hah good point...i didn't see that he had the d'series still
trav39562
Mar 31, 2009 04:39 PM
.adam.
Mar 2, 2007 03:39 PM
kid-crx
Apr 19, 2005 07:16 PM
jap-spec
Jan 16, 2003 09:35 PM
I_know
Dec 21, 2002 07:07 AM
