96 Integra No Blinker Lights
I had to install a new dash harness into my 96 integra gsr... everything works but the blinker lights they dont evern light up on the cluster... but the flashers work.. (wierd) In the process of installing the new dash harness... i cut some wires from the aftermarket alarm system... could that be a problem? All fuses are good.. and the relay still clicks and i replaced the turn signal switch... someone please help..
if you cut the alarm wires, i don't know how it could really affect your cluster. do the lights flash when you arm your car? it's just the blinker part in the cluster that doesn't work right? outside of the car is still working?
Xathine
19
Feb 4, 2009 04:27 PM
Commiecircusbear
Jan 29, 2008 01:10 PM
sublimnal
Oct 12, 2007 07:09 PM
