Viper Alarm Sensitivity
Old Sep 13, 2006 | 08:12 AM
forumnoobie's Avatar
Default Viper Alarm Sensitivity
I was wondering if anyone knew how to make the viper alarm systems less sensitive. I just found out that my car alarm goes off everytime this person drives by at 10:00 am every morning. If anyone knows it would be greatly appreciated. I am not even sure of the model of the alarm since i bought the car with it already installed and also have searched the topic and do not have the manual for the alarm. thx
Old Sep 13, 2006 | 08:54 AM
Tizight's Avatar
I used to set off car alrams in parking garages for fun I set off liek 4 at once one time.
Old Sep 13, 2006 | 08:56 AM
S1NFUL RL1 619's Avatar
Default Re: Viper Alarm Sensitivity (forumnoobie)
i have the viper 791xv, and to my knowledge, you can't adjust the sensitivity weather it being less or more sensitive. i believe the clifford alarms you can do that, but then again, that's just what i've been told.
Old Sep 13, 2006 | 08:57 AM
Default Re: (Tizight)
thats tizight, would you happen to have an answer for the above stated question?
Old Sep 13, 2006 | 09:29 AM
cm zak's Avatar
Theres usually a little **** in your steering column or something that they have that you can twist with a flathead and itll adjust it, one way is more sensitive one is less...my advice tho is RTFM :/
Old Sep 13, 2006 | 09:42 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
First you need tho find the shock sencer. Most of the time its mounted to the steering colume. It should have a green-red-blue-black wires running into it. If it a viper alarm its a clear plastic box with a single red light. Find the lil orange **** on the side of it and turn it counter clock wise. This will turn down the sensetivity of it.
If its the entry level viper alarm the shock sencer is in the brain of the alarm so you would have to find the brain and adjust the black little ****
Old Sep 13, 2006 | 09:50 AM
ir0nmanx's Avatar
Default Re: Viper Alarm Sensitivity (wrx-killer-Sti eater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti eater &raquo;</TD></TR><TR><TD CLASS="quote">First you need tho find the shock sencer. Most of the time its mounted to the steering colume. It should have a green-red-blue-black wires running into it. If it a viper alarm its a clear plastic box with a single red light. Find the lil orange **** on the side of it and turn it counter clock wise. This will turn down the sensetivity of it.
If its the entry level viper alarm the shock sencer is in the brain of the alarm so you would have to find the brain and adjust the black little ****</TD></TR></TABLE>
its clock wise for less sensitivity?
Old Sep 13, 2006 | 10:01 AM
Default Re: Viper Alarm Sensitivity (ir0nmanx)
no its counter-clock-wise
Old Sep 13, 2006 | 10:12 AM
ir0nmanx's Avatar
oh oopss i guess i read it wrong, thanks for the help.
Old Sep 13, 2006 | 12:12 PM
thanks for help guys. Im going outside now to see if i can find the clear box or the "brain". Not sure how much luck i will have finding it. Everything is pretty tight and clean under there.
Old Sep 13, 2006 | 12:51 PM
Found the unit, its a Black Box under the steering column. hope i turned that small black **** in the right direction
Old Sep 13, 2006 | 01:10 PM
do you have the 791xv? cuz damn, i need to find that thing then.
btw, anybody got a hook up on replacement remotes for the 791XV?
like around $50?
Old Sep 13, 2006 | 03:56 PM
Si_chRis's Avatar
Default Re: Viper Alarm Sensitivity (S1NFUL RL1 DB7)
my sister has a viper with the two way (i dunno if u have it) on her 05 civic. She adjusted it by holding the aux and either lock or unlock. Hold both of them the same time for like 4-6 secs and the 2way will beep and u can adjust the sensitivity level by pressing the lock or unlock. If u have the manual, it'll tell how to do it.
Old Sep 14, 2006 | 08:32 AM
Default Re: Viper Alarm Sensitivity (EM1_ChRiS)
the install/user manual never said anything about adjusting the sensitivity.
iCollectStraws
Audio / Security / Video
Jul 7, 2009 12:28 AM
gus738
Honda Civic (2006 - 2015)
15
Dec 19, 2006 09:26 PM
DriveSlowHomie
Apr 19, 2006 01:19 PM
Going Postal
Nov 21, 2005 08:29 PM
hondakat
Nov 11, 2004 10:23 AM
