NEW ROTORS AND PADS INSTALLED, BUT STILL SQUEEKIN'?
Old Sep 13, 2006 | 07:11 AM
a12rnulfo's Avatar
Default NEW ROTORS AND PADS INSTALLED, BUT STILL SQUEEKIN'?
I HAD NEW BREMBO CROSS AND DRILLED ROTORS AND PADS INSTALLED, BUT I'M STILL HEARIN' LOUD SQUEEKIN'!! WHAT SHOULD I CHECK FOR?
Old Sep 13, 2006 | 07:52 AM
ramhorn15's Avatar
Default Re: NEW ROTORS AND PADS INSTALLED, BUT STILL SQUEEKIN'? (a12rnulfo)
I have that same problem but I will have an answer friday
Old Sep 13, 2006 | 08:07 AM
HoUTX98GSR's Avatar
Default Re: NEW ROTORS AND PADS INSTALLED, BUT STILL SQUEEKIN'? (ramhorn15)
thats happened to me before. i dont think its a big deal. There is some sort of spray that you spray on new brakes... not sure what kind of spray it is.. but it may help.
Old Sep 13, 2006 | 08:54 AM
crx_88_si's Avatar
did u do the front and rears?
did u use the anti-sqeek goop and the shims?
what pads?
Old Sep 13, 2006 | 09:45 AM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a12rnulfo &raquo;</TD></TR><TR><TD CLASS="quote">I HAD NEW BREMBO CROSS AND DRILLED ROTORS AND PADS INSTALLED, BUT I'M STILL HEARIN' LOUD SQUEEKIN'!! WHAT SHOULD I CHECK FOR? </TD></TR></TABLE>
Did you bed them properly?
Did you use any anti-squeal compound on the back of the pads?
Did you adjust the wear indicators correctly?
Old Sep 13, 2006 | 09:49 AM
yee SERIOUS's Avatar
Default Re: (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">did u do the front and rears?
what pads?</TD></TR></TABLE>
Old Sep 13, 2006 | 09:56 AM
Sijray21's Avatar
if you're using HP+ pads they will squeal thanks to the metal in the brake pad compound. Other brakes squeal as much because of the similar compound.
regardless, more details will need to be said for a proper diagnosis
Old Sep 13, 2006 | 10:57 AM
ND40oz's Avatar
Default Re: (Sijray21)
I have brembo slotted and gransport 6 pads on my DC4, it squeeks a little, but it's definitely from the dust, once I clean my wheels it stops for a few days and then comes right back. But it certainly stops great.
Old Sep 13, 2006 | 11:04 AM
projectTeG's Avatar
are they cheap pads? that can cause squeaking too if they have to much metalic in them. also bad break hardare can cause a squeak.
Old Sep 13, 2006 | 01:36 PM
hvn4life's Avatar
Old Sep 13, 2006 | 02:09 PM
Lavisracing's Avatar
first are the pads chamffered on the edges and did you break the rotors and pads in right? doing 60-10mph like 5 or 6 times then driving for a while with little to no stopping. helps work the breaks in to your car. but check the edges first.
Old Sep 13, 2006 | 05:57 PM
a12rnulfo's Avatar
OK, Now to answer some question's: the rear brakes where not done, and about 20 minute's after having the front brakes installed i HAD to brake really hard and fast on the freeway[I HAD TO BRAKE FROM ABOUT 50MPH TO A STOP , TO AVOID HITTING THIS IDIOT WOMEN IN A CLK!!] ] I recently removed the pads and applyed some anti-noise lupe and the noise went away for about 1 week , but the noise returned,i did not apply any on the shims.
HotDC5
May 9, 2005 08:41 AM
petrv
Jan 17, 2005 04:58 PM
petrv
Feb 26, 2004 10:21 AM
B18CYAAA
Sep 21, 2003 02:09 PM
andrew n
Jun 18, 2002 12:04 PM
