B16a ECU Throwin Codes, help...
Old Apr 29, 2002 | 04:28 PM
pelotudo's Avatar
Default B16a ECU Throwin Codes, help...
I just got finished doing the coolant bypass, and almost regretting it now. I started it up, and it had BAD idle problems. I found the problem, a vacuum line...and quickly fixed. The ECU is now blinking 5 times quickly together. Anyone know what code this is? I don't have a B16 manual. After doing bypass, should I disconnect the IACV, or just leave it plugged in? Also, what kind of vacuum leaks are going to be left over now, and might they be causing the code?
jB
Old Apr 29, 2002 | 05:46 PM
Jared's Avatar
Default Re: B16a ECU Throwin Codes, help... (PeloTudo)
5 is map sensor.
Old Apr 29, 2002 | 06:11 PM
pelotudo's Avatar
Default Re: B16a ECU Throwin Codes, help... (Jared)
Yeah, I didn't have a couple of vacuum lines plugged in. I got the correct hoses on the right nipples, and everything is flowing fine
jB
jayeghatch
Sep 12, 2012 07:28 PM
kacheoh
Sep 19, 2009 11:54 PM
hecubus
Feb 26, 2007 03:07 PM
86ludeSi
May 23, 2005 08:20 AM
