D16Y8 INTAKE MANIFOLD
Old Sep 12, 2006 | 07:44 PM
YOUASKED4IT's Avatar
Default D16Y8 INTAKE MANIFOLD
IS THERE A WAY TO MODIFY A D16Y8 AUTO MANIFOLD TO WORK ON A 5 SPEED MANUAL
Old Sep 12, 2006 | 07:47 PM
Lewy. Dee Ayy's Avatar
Default Re: D16Y8 INTAKE MANIFOLD (.Red.EM2)
Old Sep 12, 2006 | 07:48 PM
TurboTagTeam's Avatar
There are extra air control openings on the flange of the mani. You will have to close them before you bolt it up. I think most people use JBWeld. Also there will be an extra nipple on the back of the mani that you will have to cap off.
Old Sep 12, 2006 | 08:01 PM
Hybrid96EK's Avatar
Default Re: D16Y8 INTAKE MANIFOLD (TurboTagTeam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTagTeam &raquo;</TD></TR><TR><TD CLASS="quote">There are extra air control openings on the flange of the mani. You will have to close them before you bolt it up. I think most people use JBWeld. Also there will be an extra nipple on the back of the mani that you will have to cap off.</TD></TR></TABLE>
auto = no IACV. 5 speed = IACV. You have to drill the manifold out (pain in the ***) if you wish to add an IACV.
Old Sep 12, 2006 | 08:07 PM
Luserkid's Avatar
First 2 posts should be deleted, post 3 should be clarified.
All auto Y8s run off a 3 wire IACV system. With that being said the manifold is not tapped for 2 wire IACV like the manual systems are. With this problem if you try to put an auto manifold on any D series minus HX, and D16y7 your going to have a major idle problem. HX and D16y7 run off 3wire IAC, so a good upgrade for these motors would be the ever so cheap Auto D16y8 intake manifold, its a plug and play to there throttle body. Now with all that being said to fix an auto y8 to run off the other D series motor youll have to drill and tap for 2wire IAC systems. Its a very easy process due to the moldings being there so it shows you were to drill and tap. Although i always line up my IAC to prepare it to be tapped and such so i wouldnt have any problems.
Now what turbotag was saying is also a problem you might run into but not a big one.
99-00 Y8 intake manifolds (doesnt matter weither its auto or manual) run an injector air source thing (pretty stupid if you ask me) and they need to be welded (either by JB weld or a good welder with aluminium. Either way its a simple fix to the problem, if you cover the holes you could run the manifold on any D series from 88 to 00 with no idle problem do to this problem.
Best manifold is the 96-98 manifold due to no air holes like the 99-00 and it could be put on any D series from 88 to 00. Even though the 99-00 have the stupid air injector system you could still run a non air injector manifold on them without a problem (tells you how important that system is huh )
Heres a picture of the tapping (not one that im proud of) with the holes set to be drilled out:
Ill try to get a picture of the air injector manifolds compared to nons later. I cant find one right now.
Old Sep 13, 2006 | 08:24 AM
Default Re: D16Y8 INTAKE MANIFOLD (Luserkid)
Thanks for clarifying It's been a while since I did mine. Mine came from a 5 speed anyway.
Old Jan 18, 2007 | 06:46 PM
turbovybez's Avatar
I thought the iacv was on the throttle body not the manifold itself.
Old Jan 18, 2007 | 06:47 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: D16Y8 INTAKE MANIFOLD (turbovybez)
ya on a auto
Old Jan 18, 2007 | 06:51 PM
Throwdown's Avatar
Default Re: D16Y8 INTAKE MANIFOLD (Throwdown)
circled the part of the air injector system
Old Jan 23, 2007 | 12:55 PM
03akkord5spd's Avatar
okay, i'm slightly confused. what would i need to do for a manual 99-00 y8 mani to fit on a 99 y7 motor?
Old Jan 23, 2007 | 01:12 PM
si937's Avatar
for 96-98 you will need to cap off the air injector in the middle of the manifold.
Modified by si937 at 4:04 PM 1/23/2007
Old Jan 23, 2007 | 01:13 PM
cbmprelude's Avatar
* B A N N E D *
Default Re: D16Y8 INTAKE MANIFOLD (Lewy.)
so any auto y8 manifold will work on a y7?
Old Jan 23, 2007 | 01:18 PM
si937's Avatar
ya but the one you want to get is 96-98 auto. no air injector. info above explains it to the T
Modified by si937 at 3:34 PM 1/23/2007
Old Jan 23, 2007 | 01:27 PM
cbmprelude's Avatar
* B A N N E D *
Default Re: (si937)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">
All auto Y8s run off a 3 wire IACV system. . </TD></TR></TABLE>
I think you meant cause I won't have to fill the air holes. What about throttle cable issues?
Old Jan 23, 2007 | 01:31 PM
si937's Avatar
sorry i didnt read what you said. i just bought a new throttle cable and bracket from honda for about 45 bucks
Old Jan 23, 2007 | 01:35 PM
cbmprelude's Avatar
* B A N N E D *
Default Re: (si937)
ohh, did you notice much with the y8 manifold?
Old Jan 23, 2007 | 02:01 PM
si937's Avatar
huh?
Old Jan 23, 2007 | 02:31 PM
cbmprelude's Avatar
* B A N N E D *
Default Re: (si937)
sorry, did you notice much performance gains with your y8 manifold swap ( assuming you do it)
Old Jan 23, 2007 | 03:10 PM
si937's Avatar
ya. i been reading about doing some upgrades on my d16y7 motor. more were leaning towards it doesnt made that much of a differents. i ended up just doing y8 IM and it was a big notice (pull harder from Mid to top-end). if your running the stock y7 IM i would highly recommand doing the IM swap.
Old Jan 23, 2007 | 03:13 PM
Throwdown's Avatar
Default Re: (si937)
also JB weld the air injector holes that i circled in the picture
Old Jan 23, 2007 | 03:16 PM
si937's Avatar
Default Re: (Throwdown)
Old Jun 1, 2007 | 08:29 AM
marksae's Avatar
Default Throttle Body Cable Plate
I'm about to swap a D16Y8 manifold onto my Y7 motor. I was planning on using my Y7 throttle body, but the throttle body cable plate looks to be oriented the wrong way. It doesn't look like the throttle cable will attach at a good angle. Do I need to change that as well?
Old Jun 1, 2007 | 09:36 AM
Bense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Throwdown &raquo;</TD></TR><TR><TD CLASS="quote">
circled the part of the air injector system</TD></TR></TABLE>
is this my old manifold? if so you cleaned it up a lot
Old Jun 1, 2007 | 09:38 AM
Bense's Avatar
Default Re: D16Y8 INTAKE MANIFOLD (Bense)
plugged with 10-32 set screws on my euro R manifold, but 99-00 y8 mani can be done in the same way
SRCivic97
Jul 13, 2005 11:30 PM
atc5
14
Nov 23, 2004 06:37 PM
lilcasino
Nov 10, 2004 12:06 PM
fastcrxsi90
Apr 25, 2003 07:08 PM
Quetzolcotl
Oct 23, 2002 11:52 PM
