bitch pin replacement
You can, and actually alot of people do it.
However, you will get play in the shifter. The bitch pin is made to counteract that. Do it if you want, but you'll replace it for the better driveability eventually.
getting it in is easy, getting it out is just alittle harder, just buy a flat tip punch, theres one i forget the size that is a perfect fit. you cant use the pointed punch because then the pin will just expand and it will be harder to get out
the punch is like 1/4" i think. the trick is, put the front of the car on jackstands as high as you can, so you can swing the hammer hard. it took me a while to learn, but you just gotta beat that bitch pin into its place.
Someone on here made a bitch pin removal tool with a c-clamp. Let me see if I can find the link.
EDIT: Here you go: https://honda-tech.com/zerothread?id=1672527
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDACURA-DB8 »</TD></TR><TR><TD CLASS="quote">1/4 pin punch & air hammer is all you need if you have a compressor. If not, just get the pin punch, a hammer and have fun!</TD></TR></TABLE>
it takes literally 10 seconds with an air chisel and an 8mm punch, i usually just use a conical attachment on the chisel and it works like a charm.
The "bitch pin" is called a roll pin. Get a roll pin punch (sold at your local Sears). Once you have the right tool it takes very little effort to get the pin out and re-install it. I usually TAP it with the hammer instead of beating on it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 »</TD></TR><TR><TD CLASS="quote">Someone on here made a bitch pin removal tool with a c-clamp. Let me see if I can find the link.
EDIT: Here you go: https://honda-tech.com/zerothread?id=1672527</TD></TR></TABLE>
I bought one. It broke the 1st time I used it. The C-clamp wasn't strong enough for the almighty bitch pin.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman »</TD></TR><TR><TD CLASS="quote">I bought one. It broke the 1st time I used it. The C-clamp wasn't strong enough for the almighty bitch pin.</TD></TR></TABLE>
so did the guy take care of you?
Unsivil_audio
23
Feb 16, 2010 07:54 PM
streetracerof06
Oct 27, 2005 09:20 AM
sivik2nr
Jan 15, 2003 08:38 AM
