oil consumption
Well my pesky D15 engine with 330, 000km's is burning oil at a very very unreasonable rate. At 500 km's i've already burned 3/4 of a liter so I figured rather than swapping out the motor that I try a can of ametech's engine restore. Interestingly enough the little can designed for 4 cylinder cars actually helped a lot! Anyone here tried using the ametech's engine restore with sucess?
Everytime I stepped on the gas before it would smoke and burn oil. Now even with someone's bright headlights behind me I can't see ANY smoke.
impressive to say the least....
its a temporary solution to a perment problem. its like pouring syrup in there. don't plan on it lasting for long. sounds like you need rings and/or valve seals
