Tuning past 12 psi (afr)
Old Sep 12, 2006 | 12:05 PM
Boosted Chemist's Avatar
Default Tuning past 12 psi (afr)
I did a search, there is a ton of info on tuning from 0-12psi, i got that down. So here I am at 13 psi with 11.5 afrs, I know u have to drop the afrs as you go up with boost, but is there a general rule of thumb?
Btw this is a build b16a, if that matters
Old Sep 12, 2006 | 12:08 PM
93turbo16's Avatar
Default Re: Tuning past 12 psi (Boosted Chemist)
Things just don't magically change after you go above 12 psi. You are fine with that AFR.
Old Sep 12, 2006 | 12:12 PM
Default Re: Tuning past 12 psi (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">Things just don't magically change after you go above 12 psi. You are fine with that AFR.</TD></TR></TABLE>
I didnt think so, but as you go from 0-12 it steps down from 12.5-11.5, i plan on running 20+psi, is it safe to run 11.5 or do people go down even farther to 10ish?
Old Sep 12, 2006 | 12:14 PM
93turbo16's Avatar
I surely don't tune much of anything to 12.5 afr on a street car. I alway stay anywhere from 11.8-11.4 on street cars. You really shouldn't be in the 10s, that is rather rich. I would stay mid 11s even at 20 psi and it should be fine. Timing is the bigger factor.
urbansi's Avatar
I thought that was the change over point from USDM to JDM.
No but seriously i think you may want to look into pulling timing when you start adding boost. Whats your EMS, does it have a step retard???
Old Sep 12, 2006 | 12:17 PM
Default Re: Tuning past 12 psi (urbansi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbansi &raquo;</TD></TR><TR><TD CLASS="quote">
No but seriously i think you may want to look into pulling timing when you start adding boost. Whats your EMS, does it have a step retard???</TD></TR></TABLE>
I though my motor was in "jdm" mode until it hit boost with my usdm parts
Im running a step retard, and i pulled alot of timing, which i dont plan on adding until i get on a dyno. I just wanna get my afrs mint until i get dyno time. Im running crome abt2.0
stokcivic
11
Nov 20, 2006 05:38 AM
TheGsR99
Nov 6, 2005 06:36 PM
slotec
Aug 30, 2005 09:37 AM
BoOsTiN Dc2
Aug 6, 2005 09:55 PM
SoHc84
May 27, 2005 08:25 AM
