hard to to drop car in reverse
Old Sep 12, 2006 | 08:03 AM
ieatrice's Avatar
Default hard to to drop car in reverse
whenever i try to go in reverse, sometimes it won't go in at all.. i gotta sit in the parking lot for like 3 minutes, shifting in a forward gear, pumpin the clutch, and everything and then finally it goes into reverse? what could the problem be??
Old Sep 12, 2006 | 08:27 AM
CardDealer's Avatar
Banned
Default Re: hard to to drop car in reverse (ieatrice)
Modified by CardDealer at 9:09 AM 11/16/2006
Old Sep 12, 2006 | 08:30 AM
alacard's Avatar
Default Re: hard to to drop car in reverse (schlit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schlit &raquo;</TD></TR><TR><TD CLASS="quote">If you've ground your reverse gear too many times, the gear teeth can become messed up to the point it becomes that difficult to engage.
Remember, reverse doesnt have a syncro on it and it is a square cut gear, so normally, it's not the easiest gear to go in. That's why you usually have to pause a second or two before shifting into it to let everything spin down and come to rest......and is why so many people grind it to hell.</TD></TR></TABLE>
good info...i always wondered why reverse was a bitch.
Old Sep 12, 2006 | 08:38 AM
B18bEG6ick's Avatar
Default Re: hard to to drop car in reverse (alacard)
it makes it easier if you go to a forward then to reverse. for me its first gear then to reverse.
Old Sep 12, 2006 | 09:01 AM
B18B1_4DR's Avatar
Default Re: hard to to drop car in reverse (B18bEG6ick)
This happens to a lot of people. If you're just sitting in your driveway trying to backup and it won't go into reverse. Put the clutch in, go into 2nd quick, then goto reverse. Just a little trick.
Old Sep 12, 2006 | 09:24 AM
ieatrice's Avatar
Default Re: hard to to drop car in reverse (B18B1_4DR)
thanks for the tip guys. i do put it in a forward gear before i drop it in reverse.. but sometimes it just won't go in. it can even take up to like a whole minute until it finally goes in!! ugh, so irritating.. but yeah.
Old Sep 16, 2006 | 07:53 PM
TinyTitan's Avatar
i'm having the same issue, damn thing will not go into reverse right now, and this morning it got freaking stuck in REVERSE ahhhhhhh anyone can help on this issue
Old Sep 16, 2006 | 07:58 PM
Syndacate's Avatar
Tip for reverse shifting when it won't go in:
Put it into reverse as far as it'll go. Then let out the clutch VERY slowly while pulling the shifter down into reverse (with a little pressure, but not enough to force it in), when the clutch gets to a certain point, it'll slide right into reverse and it won't be engaging the clutch quite yet, so you won't move or stall or anything. Works every time.
Old Sep 16, 2006 | 07:59 PM
tha_badguy's Avatar
what if it wont go into reverse at all
its like blocked out of reverse completely
what would make that happen?
Old Sep 16, 2006 | 08:02 PM
hyper209's Avatar
Default Re: (tha_badguy)
lets save some bad temper for later buy a used tranny....200 $ the most..........
Old Sep 16, 2006 | 08:18 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tha_badguy &raquo;</TD></TR><TR><TD CLASS="quote">what if it wont go into reverse at all
what would make that happen?</TD></TR></TABLE>
I'm talking about if it goes in but it doesn't go in all the way (and if you let otu the clutch it won't do anything or it will grind). If it won't go in at all, like it's blocked out (as if here's not a slit there to slide it into reverse) then it's a different problem. Sounds like a saftey catch (which is non-existant on a civic, see them on cavaliers all the time) or the clutch system isn't working right (maybe a leak) - if that's not it, I suppose it's possible the idler gear is shot. Reverse complete lock outs are weird, if you mean that it just won't slide in to the point where you can drive backwards, refer to my tip, just put it as far as it'll go and slowly release the clutch while pulling it towards reverse (lightly, but enough to shift).
Old Sep 16, 2006 | 08:30 PM
M2S~Juan's Avatar
I always do 4th---&gt;R
Old Sep 16, 2006 | 08:43 PM
swifty4u's Avatar
Default Re: (juan671_M2S)
I go first then reverse, sometimes it still doesnt go and i let the clutch out like an inch and rev and it will drop in like butter and dont grind...pretty weird but hey whatever works
Old Sep 16, 2006 | 08:52 PM
Syndacate's Avatar
Try it the way I told you about - then decide which one you like better.
Don't have to rev it or anything, just let the clutch out slowly and it'll go in, then ur like 1 cm from the grab point so you can just give it gas and pull it and go...with practice you can do it in half the time it takes to shfit from 4th to reverse.
NoPainNoGain
Honda Civic (2006 - 2015)
21
Feb 2, 2007 10:37 AM
808k20z3
Jan 21, 2007 10:55 AM
jdm_DC2R
Mar 21, 2006 08:37 AM
TurboTagTeam
Oct 18, 2004 09:01 AM
slammeddelsol95
18
Jul 19, 2004 01:44 PM
