a/f ratio at idle??help
Old Sep 12, 2006 | 05:04 AM
jamartin0519's Avatar
Default a/f ratio at idle??help
I just got finished with my turbo install. Im runnung a hondata s200 with a base map from my tuner. When I start the car it runs very rough and dies. The idle goes up and down the whole time. My a/f is ~14.5 when I first start the car. I have a plx 300 that is running by itself. The stock narrow band is still in place. What do you guys idle at?Help Im stressing!
Old Sep 12, 2006 | 07:06 AM
adseguy's Avatar
Default Re: a/f ratio at idle??help (jamartin0519)
The plx starts at 14.5-14.8 because it's not warmed up....give it about 30-40 seconds and it will give you the true readings. If you can't even idle something is wrong with the basemap (could be wrong injector size)
Old Sep 12, 2006 | 07:11 AM
JDMisGOOD's Avatar
Default Re: a/f ratio at idle??help (adseguy)
Yeah your sensor needs to warm up.
Your set-up definately needs tuning! Have the issue addressed asap before you do any damage.
Old Sep 12, 2006 | 07:33 AM
Default Re: a/f ratio at idle??help (JDMisGOOD)
Thanks guys...I will be calling my tuner as soon as they open.
Old Sep 12, 2006 | 08:23 AM
iBrandon's Avatar
what size injectors and ems u running?
Old Sep 12, 2006 | 10:12 AM
GetawayInMoscow's Avatar
Default Re: a/f ratio at idle??help (iBrandon)
The timing/fuel maps shouldnt have to be adjusted too much to get the car to idle pretty well.
Check to make sure you told your tuner the right injector size.
Old Sep 12, 2006 | 10:25 AM
turbotime's Avatar
make sure you have the IACV hooked up 2- i forgot when i started my build and the thing kept dying wouldnt hold idle for chit. plugged it in and it ran great, just a thought....
Old Sep 12, 2006 | 11:14 AM
Turbo-LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jamartin0519 &raquo;</TD></TR><TR><TD CLASS="quote">I just got finished with my turbo install. Im runnung a hondata s200 with a base map from my tuner. When I start the car it runs very rough and dies. The idle goes up and down the whole time. My a/f is ~14.5 when I first start the car. I have a plx 300 that is running by itself. The stock narrow band is still in place. What do you guys idle at?Help Im stressing! </TD></TR></TABLE>
you answered your own question with the first post
BASE MAP
Old Sep 12, 2006 | 11:23 AM
turbotime's Avatar
Default Re: a/f ratio at idle??help (Turbo-LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-LS &raquo;</TD></TR><TR><TD CLASS="quote">you answered your own question with the first post
BASE MAP</TD></TR></TABLE>
no. a base map should idle almost perfect as the idle map is almost identical to stock aside from minor changes for the larger injectors.
My car idled like stock on a BASEmap, just a lil rich. Saying that its idling like **** cause its a basemap is just plain wrong.
Either your tuner mapped you for the wrong size injectors or something in the engine is wrong or not connected right.... any vacuum leaks? Any CELs?
Old Sep 12, 2006 | 12:21 PM
Default Re: a/f ratio at idle??help (turbotime)
Im running 750cc injectors. I just got back from my tuner. At the time of the base map being burned the first time he forgot to program that I map a gm 3-bar MAP sensor. The car idles fine now.
posjr
Engine Management and Tuning
11
Sep 9, 2014 08:05 PM
xRacerX81
Jul 2, 2008 12:28 PM
welfarepc
Sep 13, 2007 05:15 PM
eg:R
Mar 26, 2006 10:23 AM
