CRX mini-me turbo hooked FMU and now fuel pump makeing noise >!>!!
Old Sep 11, 2006 | 11:17 PM
catchthis92hatch's Avatar
Default CRX mini-me turbo hooked FMU and now fuel pump makeing noise >!>!!
aight so i am in the process of turboing my mini-me crx and i am haeing to use a FMU for the time being till more money gets her and i get my ecu chipped anyways i cut the key on and my fuel pump is like whineing all the time now while its on i mean could this be because of the upgrade in PSI or the facted the car is up on ramps at a angle or what im lost kinda worried bout it do i need a new pump let me know thanks
chris
Old Sep 12, 2006 | 10:12 AM
1 Fly SI's Avatar
Default Re: CRX mini-me turbo hooked FMU and now fuel pump makeing noise >!>!! (catchthis92hatch)
Mine did the same thing on my SC setup untill my ringlands broke. The whining noise is normal but the fmu is crap.
Old Sep 12, 2006 | 11:19 AM
crxnj's Avatar
when you use the fmu you need to run a high flow inline pump to...the stock intank pump alone cant handle the pressure at all (a walbro 255 cant even)...you put it between the fuel filter and fuel rail under the hood,,its fairly simple to install,,just cut a section out and clamp it on,,then wire the ground,and power to a switched ignition..
but that whining you describe,,it wouldnt just happen when the car is idling,,it would strain the fuel pump under boost when the fmu raises fuel pressure....maybe it was cause of the angle of the car? im not a fuel pump expert
Old Sep 12, 2006 | 04:55 PM
sohcvtec1995's Avatar
step one- get rid of fmu
TOP*SECRET
Apr 21, 2005 08:37 PM
blackccoupe
Apr 1, 2004 08:09 AM
b18tdelsol
May 19, 2002 07:09 PM
SlowB16
Jan 27, 2002 11:15 AM
c-notecoupe
Jan 14, 2002 09:10 PM
