i am running 14 iddle air controle...
Locate the IAC, it's on the back of the intake manifold. Undo the bolts holding it in, then lean it back against your firewall to look inside, it should be DIIIRRRTY. DO NOT UNHOOK THE COOLANT LINES RUNNING INTO IT! Clean it out really well with carb cleaner or MAF cleaner (until no more dirt comes out). Reinstall, if it doesn't do the trick ,follow the tseting procedure in a repair manual. Good luck.
shiux
Oct 25, 2008 08:59 AM
TypeR0207
13
May 29, 2002 06:12 AM
