Help code 14
Old Apr 8, 2009 | 07:40 AM
DC2teggY's Avatar
Default Help code 14
Alrightly I have a 90 interga with a b17 in it and I have a solid check engine light. When I check the codes I get a code 14 and thats it? I found out that code 14 is electronic air control but I have no clue what that is. Does anyone have any idea what that could be?
Old Apr 8, 2009 | 07:42 AM
DC2teggY's Avatar
Default Re: Help code 14
Also it was idling really low like 500 so I turned it up and if it goes above 1000 at idle the tach starts bouncing by it self like its hitting 2 step.
Old Apr 8, 2009 | 09:39 AM
mouab18c1's Avatar
idling at 500 is perfect..1000 i think is high if the car is just sitting there
Old Apr 8, 2009 | 11:06 AM
1DayIllBFast's Avatar
Code 14 is for your IACV (Idle Air Control Valve) it should be located on the back of your intake manifold. It should have two coolant lines going to ti and a plug which is the connector. It should have 2 bolts going into it. You can undo those bolts and there will be 2 holes for each of the coolant lines. One hole will have a screen on it you need to make sure this screen is clean and has no junk in it. You can also check the voltage on the connector it should be 5volts. You can also google ways to test and clean it. I hope this helps.
SLEEPIN-GSR
Jun 23, 2009 02:06 PM
team 15
Apr 21, 2008 05:49 PM
civic4dr2000
Apr 2, 2006 04:41 PM
Jdmb18EF
Jan 17, 2006 05:34 AM
