ZC swapped EF, pilot bearing does not fit flywheel (Si trans)
helps! .. I'm doing a clutch for a friend, he supplied an OEM Exedy clutch kit, and the pilot bearing that came with the kit is too large to fit the flywheel, it almost appears the spline fits snug on the flywheel? .. I've researched and come up with no real info, other than on the ZC there may be a bushing rather than a bearing? .. anyone have any info to share?
Spline isn't the problem, its the lack of a pilot bearing .. anywhere! When I took apart the clutch, there was no pilot bearing to be found anywhere. pics ftw/l
front side of flywheel:
back side:
crank mating surface:
trans spline:
the problem:
back side:
trans spline:
the problem:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IndySporty »</TD></TR><TR><TD CLASS="quote">isn't that the said bushing there in the flyhweel?</TD></TR></TABLE>
If you're talking about the bearing sitting on the flywheel in the last pic, that's the bearing that he bought to install, I placed it there for reference to the size of the hole it should fit in from behind.
I'm thinking that too, but I'm so used to seeing the impression on the back of the flywheel, trips me out .. as well, where the hell is the old one? lol .. that is what is really confusing me.
the flywheel you have is from 86-89 Integra which didn't use a pilot bearing - the input shaft was supported by the flywheel without a bearing - my guess is you don't have a ZC engine, but have a Interga D16A1 - running L3 transmission without a pilot bearing is going to quickly end up with toasted input shaft bearing in the transmission
this is 86-89 Integra transmission input shaft
Modified by jlicrx at 8:58 AM 9/12/2006
D16SiHatch
Apr 2, 2008 02:13 PM
ahemming06
Feb 10, 2007 11:59 AM
jadugartir
Nov 22, 2006 10:07 AM
redlineintegra
Sep 11, 2006 07:24 PM
