help with turbo ID and power output
Old Sep 11, 2006 | 07:18 PM
sloganish's Avatar
Default help with turbo ID and power output
i currently have what i think to be a turbo off an srt-4, it has a .42 cold side .48 hot, what would this be efficent power wise up to for a stock gsr setup? also can anyone identify whether or not this is the turbo i think it is, pics are below
Old Sep 11, 2006 | 07:40 PM
N20civicB18's Avatar
Default Re: help with turbo ID and power output (sloganish)
thats not a srt4 turbo.... srt4 turbos have the turbine housing built into the exhaust manifold
Old Sep 11, 2006 | 07:45 PM
sloganish's Avatar
hmmm i never knew that, i dont see how that would work but ok. anyone know more about this,
i believe its a 45 trim if that helps
Old Sep 11, 2006 | 07:55 PM
IIISport.com's Avatar
Default Re: (sloganish)
You have a .42 something. There should be a similar marking on the exhaust housing. That will be on the small end for a 1.8L IMO.
Old Sep 11, 2006 | 07:56 PM
CRX_1.8T's Avatar
Doesn't Volvo use the 42?
Old Sep 11, 2006 | 08:04 PM
sloganish's Avatar
yeah its a .42 cold .48 hot
Old Sep 11, 2006 | 08:40 PM
Got_soy's Avatar
Its a crappy chrysler t3, it has a wierd flange.
Old Sep 13, 2006 | 09:48 AM
sloganish's Avatar
crappier than using a t25?
Old Sep 13, 2006 | 10:12 AM
Got_soy's Avatar
the chrysler t3 is internally like every other small t3 but its flanges are all different. Neither this or a t25 would work well with a gsr, you could get a 60/63 from thunderbirds, that would be a hell of alot better
Old Sep 13, 2006 | 11:13 AM
sloganish's Avatar
well as far as the flange, thats not a problem, im having an adapter plate welded together, how much efficent power can this turbo afford me? im really only shooting for around 250whp, and im having it tuned,
Old Sep 13, 2006 | 11:37 AM
Got_soy's Avatar
dp flange is different aswell. i have the same sized turbo for my zc and im expecting boost at around 3kif not sooner,on a gsr its gonna spool stupid fast. you best be would be to find a compressor map and plot **** out. I would help more if i knew more
jfruauff
May 6, 2007 05:02 PM
turbosol_16
Dec 27, 2006 06:41 AM
B6tPoweredMx3
Jul 8, 2006 02:48 PM
boostdummy
Jan 21, 2006 09:18 PM
Civicdrgrcr
Jun 17, 2002 11:09 PM
