Need HELP!...B*T#*H Pin wont come off tranny/shift linkage...any suggestions?
Old Sep 11, 2006 | 07:02 PM
loosestool's Avatar
Default Need HELP!...B*T#*H Pin wont come off tranny/shift linkage...any suggestions?
The car is on jack stands and I dont have enough space to get any good hammer swings with the punch to punch it out. I tried using a jack under the punch and it didnt seem to help. This is on a y1 tranny if that helps.
Should I drill it out? This seems to be my last option unless there is a special tool beside a punch used to get this out..if thier is such a tool can anyone show my pics or suggest a website that sells them or would a auto store rent these out?
Old Sep 11, 2006 | 07:04 PM
Got_soy's Avatar
Default Re: Need HELP!...B*T#*H Pin wont come off tranny/shift linkage...any suggestions? (loosestool)
are you taking the trans off? or the whole engine out?
Old Sep 11, 2006 | 07:07 PM
Tippyman's Avatar
I bought a tool some guy invented called a B.P.E. (bitch pin extractor) it broke first time I used it. the bitch pin was too much for it.
Take the trans or engine out with the shift linkage attatched. Just undo the shift linkage from underneath the shifter, and then undo the linkage stabilizer bar from the tranny. Then undo the bitch pin once it's out and you have room to really whack the hell out of it.
Old Sep 11, 2006 | 07:32 PM
Boosted Chemist's Avatar
Default Re: (Tippyman)
use an a/c bolt, it works perfect
Old Sep 11, 2006 | 07:34 PM
Got_soy's Avatar
Default Re: (Boosted Chemist)
you can leave the linkage on disconnect it at the shift then tap it out, its what i did when i swaped my engine
Old Sep 11, 2006 | 07:41 PM
loosestool's Avatar
Default Re: (Got_soy)
problem is the engine is swaped in already.
Whats the A/C bolt trick?
Where do I get a B.P.E?
Old Sep 11, 2006 | 09:41 PM
90b20vteckidd's Avatar
Default Re: (loosestool)
i think its called a cobalt drill bit? someone correct me if im wrong. but go to loes and buy one of those...drill the bitch out and buy a new one from honda. thats your best bet. gooooood luck my friend
Old Sep 11, 2006 | 09:59 PM
99LudeDude's Avatar
keep trying. It isn't called the bitch pin for nothing. It'll come out eventually.
Dr.Fixit
Oct 22, 2013 12:42 AM
mmmbrapND
Transmission & Drivetrain
Apr 7, 2009 06:18 PM
AViciousTHRUST
Dec 6, 2006 12:11 AM
cincispeedemon
Oct 9, 2004 02:55 PM
sabertooth
Jan 9, 2004 10:23 PM
