will a b18c fit into 89 crx si?
Old Apr 29, 2002 | 12:08 PM
sbplay22's Avatar
Default will a b18c fit into 89 crx si?
i want something bigger then a normal b16a swap. i don't know if the b18c will fit or if it does is there room for a turbo? if not a b18c then what can i fit that would give it more pep?
Old Apr 29, 2002 | 12:20 PM
G a b e's Avatar
Banned
Default Re: will a b18c fit into 89 crx si? (sbplay22)
yes
Old Apr 29, 2002 | 01:05 PM
wuhungsixxx's Avatar
New User
yes...you need to cut a bit of the hood supports or get a SiR hood to clear the valve cover...
turbo can be done with a different radiator and a different x-member
Old Apr 29, 2002 | 01:09 PM
Urban Business
Guest
Posts: n/a
Default Re: will a b18c fit into 89 crx si? (wuhungsixxx)
use hcp mounts, moves motor twards back of car so you have clearance for turbo. also valve cover sits back further which *should* eminate cutting webbing from hood
Old Apr 29, 2002 | 01:25 PM
HybridRexy's Avatar
Just did the b18c swap into my 89 crx si, the only problems I had were hood clearance and front crossmember clearance(where the front mount used to be with sohc motor), just banged it out> Otherwise it was all good
hondatuner020
11
Mar 27, 2015 04:35 AM
crxman1983
13
Jan 6, 2006 03:45 PM
apexinghonda
May 12, 2004 04:41 PM
hurleyburley
Feb 18, 2003 11:15 AM
ChaseIntegra
Apr 3, 2002 09:07 AM
