Suspension & Brakes Theory, alignment, spring rates....
might be dumb question but.. can suspension be installed wrong way?
Old Sep 10, 2006 | 09:24 PM
J.nguyen's Avatar
Default might be dumb question but.. can suspension be installed wrong way?
ok, well just wondering but i had my motor swap done, but while the fork was out on the hub, i removed my passenger side suspension "megan racing street suspension" and i tried to lower it all the way , then i put it back and didnt know which way to screw it back on.. so i just guessed and put it back on. i didnt fck with anyting else, i just simply took it off, spinned the coils, then put it back on.. would it matter if it were up in the wrong direction or anything?
Old Sep 11, 2006 | 07:03 AM
J.nguyen's Avatar
Default Re: might be dumb question but.. can suspension be installed wrong way? (Jesse.)
Old Sep 11, 2006 | 11:02 AM
My95SlvrBlt's Avatar
What do you mean screw it back on?
Old Sep 11, 2006 | 11:15 AM
J.nguyen's Avatar
Default Re: (My95SlvrBlt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by My95SlvrBlt &raquo;</TD></TR><TR><TD CLASS="quote">What do you mean screw it back on?</TD></TR></TABLE>
like u take off the whole suspension coilover module and u just screw it back on where the top 2 bolts go that would also hold the strut bar.
Old Sep 11, 2006 | 11:32 AM
PIC Performance's Avatar
Default Re: (Jesse.)
The shock forks in the front are directional - one side faces forward, one faces rear, and this is to accomodate the axle. Yes it is possible to install the suspension backwards.
Old Sep 11, 2006 | 11:45 AM
J.nguyen's Avatar
Default Re: (PIC Performance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PIC Performance &raquo;</TD></TR><TR><TD CLASS="quote">The shock forks in the front are directional - one side faces forward, one faces rear, and this is to accomodate the axle. Yes it is possible to install the suspension backwards. </TD></TR></TABLE>
so how do i know if ive installed it the wrong way? ive been driving around with it like this for about a week, been hearing a little strange noise from suspension but dunno if thats the reason?
Old Sep 11, 2006 | 12:06 PM
You probably left the perch improperly tightened, or it loosened causing some slop.
Old Sep 11, 2006 | 12:07 PM
J.nguyen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by My95SlvrBlt &raquo;</TD></TR><TR><TD CLASS="quote">You probably left the perch improperly tightened, or it loosened causing some slop.</TD></TR></TABLE>
i tightend them real good. but ill double check. so u want me to tighten the top hats where the strut bar goes? also HOW do i know if i put my suspension in the right way..
Old Sep 11, 2006 | 12:28 PM
gogogomoveit's Avatar
I dont think the brake line will bolt correctly onto a backward-installed shock. Thats a very good sign. But my friend did installed his Zeal coilover backwards on a Subie and totally messed up the front tire after 10k miles.
Old Sep 11, 2006 | 12:29 PM
J.nguyen's Avatar
Default Re: (gogogomoveit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gogogomoveit &raquo;</TD></TR><TR><TD CLASS="quote">I dont think the brake line will bolt correctly onto a backward-installed shock. Thats a very good sign I believe. But my friend did installed his Zeal coilover backwards and totally messed up the front tire after 10k miles. </TD></TR></TABLE>
i don thave ABS. iono if that does anything with installin git backwards.. BUT how DO I KNOW if it was installed backwards or not?!?!?!? theres only 2 ways htey can go in. 50 / 50 chance!
CivicKid517
Classic Hondas
Nov 26, 2007 04:05 AM
Tippyman
Sep 2, 2006 01:24 PM
failed
Sep 1, 2005 05:25 AM
jond
May 5, 2003 01:24 PM
sleedawg
Jan 4, 2003 07:09 PM
